stupid question... developing tank
Discussion in 'The Darkroom' started by hammy, Jan 22, 2006.
  1. hammy
    hammy TPF Noob!
    Aug 6, 2005
    149
    I have a stainless steel developing tank. It has 3 canisters in it, one for 35mm and two others for medium format...
    How do I develop just a single 35mm roll in it? Do i take the other two canisters out and let the single 35mm slide around? Or keep them in?
  2. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,373
    2,838
    In the mental ward of this forum
    I've only used Paterson tanks (plastic) with plastic reels. I have a dual tank but am usually only developing one roll at a time, and I removed the other reel long ago. It doesn't slide around at all - no problem! Can't imagine it would be any different with your stainless. :)
  3. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I would keep the extra reels in the tank. My thinking is that went empting or flipping the tank the reel will slide for end to end, not sure if that is bad or not, a plastic tank will not do this because reels are locked in place on the center post
  4. df3photo
    df3photo TPF Noob!
    Dec 31, 2004
    629
    Erie Pennsylvania
    I would leave the emptys in also. It seems you would get a more even flow of chemicals across your film instead of the real possibly sliding with the used chemical...
    I would leave it in.
  5. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Leaving the other reels in or not depends upon your method of agitation.
    If you do the inversion method (turning the tank upside-down) then you need to leave the other spirals in to stop the one with the film on sliding up and down on the core. This can take it out of the dev and it will not process correctly.
    If you use the Kodak figure-of-eight method then you can safely take them out as the tank isn't inverted (less to wash with this method ;) )
    Remember that if you are processing only one film you only need to use enough chemicals to cover that spiral, you don't need to fill the tank.
