Stupid question?
Discussion in 'Beyond the Basics' started by Jimmy The Bat, Feb 16, 2010.
  1. Jimmy The Bat
    Jimmy The Bat TPF Noob!
    Aug 30, 2008
    55
    Massachusetts
    I'm sure this is a stupid question but i dont understand,Its about f stops on lenses.I have an 18-55mm f/3.5-5.6 lens, I understand that at 18mm it is f/3.5 and at 55mm it is f/5.6. But my question is I can adjust my command dial on the camera to f/22. the largest aperture is f/3.5, but is the smallest f/5.6, or can I go to f/22? I hope this is understandable,I had a hard time trying to explain what I'm asking. anyway,thanks in advance for any help.
  2. Overread
    May 1, 2008
    24,002
    4,152
    UK - England
    The largest aperture is a tricky thing because its backwards:
    At 18mm your largest aperture is f3.5 - your smallest f22
    At 55m your largest aperture is f5.6 - your smallest f36
    The blades themselves won't actually adjust, but the act of zooming changes the properties of the lens - reducing light entering the setup and creating the same situation as if the blades had been closed.
  3. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Incorrect as stated since you failed to define "it". This lack of definition is, perhaps, a big part of your confusion.
    Correct statement would be "... at 18mm the maximum aperture is f/3.5 and at 55mm the maximum aperture is f/5.6...".
    Neither of these apertures give any lead as to what the minimum aperture is. Your command dial does not "go to f/22". The minimum aperture can be a limit set by the lens. You may find that the lens limits the minimum aperture to the same f/stop regardless of focal length and you may find that the minimum aperture varies with focal length.
  4. Overread
    May 1, 2008
    24,002
    4,152
    UK - England
    *tests this*
    ahh you're right at the 55mm end the lense does change the minimum aperture as well - to f36 (at least on my canon 18-55mm I suspect nikon performs similar). my reply above edited now to reflect this
    I have to admit though that I never go that small with the aperture - ever. Past f13 diffraction starts to become a problem and that will result in softer images by far no matter how well you shoot (diffraction being a factor in lens construction).
  5. Jimmy The Bat
    Aug 30, 2008
    55
    Massachusetts
    thank you so much guys, You really cleared this up for me, Overead, I never realized that the 55mm lets you close the aperture to f/36, Just tried it on my Nikon. Anyway thanks again for the help.
