Sunset on the beach
Discussion in 'Landscape & Cityscape' started by dimwit, Jul 26, 2010.
  1. dimwit
    dimwit TPF Noob!
    May 16, 2009
    34
    MI/SC
    Went out to Sullivan's Island a few times over the last few weeks. Here are the highlights.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    5.
    [​IMG]
    C&C is both welcomed and requested!
  2. Polyphony
    Polyphony TPF Noob!
    Jun 25, 2010
    336
    New York
    These are all underexposed and some of them are very noisy.
  3. Arkanjel Imaging
    Arkanjel Imaging No longer a newbie, moving up!
    Jun 8, 2009
    1,229
    157
    SW Florida
    And obnoxiously HUGE!
  4. dimwit
    dimwit TPF Noob!
    May 16, 2009
    34
    MI/SC
    Sorry about the sizing, it's showing up on my screen as automatically resized. :confused:
    Noise is something I have been having problems with. These were all shot at a low ISO with approximately the proper shutter speed. Any ideas what I'm doing wrong?
  5. Polyphony
    Polyphony TPF Noob!
    Jun 25, 2010
    336
    New York
    Are you sure the ISO was low? like 100-200? Also use a tripod, that will help you get longer shutter speeds at low ISO with little to no apparent noise.
    Edit: Also the image size is fine, they show up extremely large while the page is loading but when it is finished, all the pictures are a nice size.
    Edit2: Btw, I really like the last one....mysterious.
  6. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    I show the ISO up at 800 on the first one....... much too high if you don't need it to get the shot, and the others at 400...
    Noise can be an irritant, so try to stay at about ISO 100 or 200, then set your aperture where you want it for DOF, etc., - and then take a look at the shutter speed and see if that's what you can work with...... Adjust shutter and aperture first to change things how you might like them (histogram check perhaps) before you ever go much higher with the ISO .... You may be much happier with the results.......:D
  7. Shaneuk
    Shaneuk TPF Noob!
    Apr 16, 2010
    88
    Derby UK
    All of them are under-exposed and quite noisy. I think that 4 is the best though.
  8. VJS
    VJS TPF Noob!
    Jul 12, 2010
    59
    New Brunswick
    Yes, these are all underexposed. The noise works on #5 really well though.
    I'd like to expand a bit on LarryD's advice...
    First, never shoot higher than ISO 200 with the exception of only THREE instances :
    #1 star shooting @ night
    #2 early morning / mid evening animal shots
    #3 You're inside, dimly lit and you have no flash
    For all other applications, 200 ISO is the max you ever need to go.
    Now, don't adjust your aperature for light gathering, especially in landscape / waterscape shots. Pick your focus and set your aperature to that. IE: if you want the 'whole thing' to be in focus, go at least F8. If you only want a piece of focus go lower than F5.6.
    Use your shutter speed to gather light, not your aperature. While, yes, aperature affects the amount of light hitting the sensor,what it MORE affects, is your focusing.
    Go back and try these again sometime with the above in your head. It will really change the way you go about taking lower lit images.
    Hope these comments help you -- keep shooting.
  9. dimwit
    dimwit TPF Noob!
    May 16, 2009
    34
    MI/SC
    Thanks for all the help!
    In the interest of some explanation: though I was shooting in manual, I was placing the priority on shutter speed so as to capture the motion of the waves in a particular way. That's not to say that I adjusted the other settings correctly, but I was attempting to adjust for (in most cases) a 0.4-0.6" shutter speed. As VJS suggested, though, I normally would adjust shutter speed to adjust light intake.
  10. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    Holy way too BIG image sizes Batman. I would definitely fix that asap.
  11. dimwit
    dimwit TPF Noob!
    May 16, 2009
    34
    MI/SC
    Should be good now. Sorry about that.
