Sunset on the cove
Discussion in 'Landscape & Cityscape' started by mdtusz, Apr 23, 2010.
  1. mdtusz
    mdtusz TPF Noob!
    Feb 10, 2010
    261
    Victoria BC
    [​IMG]
    It's a bit grainy, but meh.
  2. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    hdr? looks like it
  3. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    I think its hdr. Not bad, but i would try to clone out the ghosts (those lil circles from the sun, i think they are called ghosts).
  4. mdtusz
    mdtusz TPF Noob!
    Feb 10, 2010
    261
    Victoria BC
    Yup. It was my first attempt at HDR and came out a bit too noisy but oh well.
  5. HikinMike
    HikinMike No longer a newbie, moving up!
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    I've seen way worse! You did pretty good and I'm not a fan of most HDRs. I've always been of fan of using Layer Masks, but that's just me.
  6. carlos91
    carlos91 TPF Noob!
    Mar 16, 2010
    115
    miami
    what is HDRs
  7. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    High Dynamic Range photos, Carlos.
    Actually, in order to create true HDR-photos, you need to take at least three photos of the same scene (camera on tripod, set to auto-bracketing), one that is a bit overexposed (to bring out the shadow parts), one that is the normal exposure, and one that is a bit underexposed, to bring out the brighter parts. (You can also work with five, seven, nine photos... as you please).
    Then there is software that merges these three photos for you, and the range of correctly lit parts should be wider than a camera can capture in one exposure alone: there should be more detail in the otherwise dark, shadowy parts, coming from the overexposed photo, and parts that would normally become far too bright in one exposure only should benefit from the underexposed photo and look more "normal". You increase the light dynamics, therefore it's "High Dynamic Range". You understand?
  8. rehan507
    rehan507 TPF Noob!
    Apr 25, 2010
    11
    UK
    Beautiful picture, seems natural without any editing, if someone would be sitting at rocks it would create more pleasant image, nice picture
  9. Sachphotography
    Jun 17, 2009
    1,229
    Tulsa, OK
    It is not bad. Hdr does introduce a lot of Noise....
  10. D-B-J
    Apr 13, 2010
    9,027
    2,172
    An edit to LaFoto's post. I have made plenty successful HDR's from handheld, autobracketed shots. I simply put it in continuous high, and blast away my five frames in one second. Granted, a tripod is much easier. Haha.
