Sunset
Discussion in 'Critique Forum Archives' started by melcooney, May 24, 2006.
  1. melcooney
    melcooney TPF Noob!
    Jan 24, 2006
    578
    Indiana
    I took two pictures and PSed them together.
    I'm not so sure of the outcome. I adjusted
    the opacity of the second layer, but is it too light?
    All comments are appreciated.
    [​IMG]
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    What was it you were trying to do? Explaining will help people to be specific about their replies :hertz:
  3. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    You have to forgive Hertz he is an old film guy and does not understand Photoshop talk. So basically you made multiply print in PS. And you want to know how it come out, right?
    I will need to look at longer to give a good answer.
  4. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    First let me say I have not yet taken the time to learn is type of process and I understand you are still learning
    IMO the exposure and angles of sun to shore line look unnatural, along with the sunray being to thin. Maybe you could post the original images. And hopeful someone with better PS skills can give you some tips. Hope that did not hurt too much?
  5. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    I understand PS layers just fine - I was a Graphic designer once.
    I was making the point that this is Critique and not the PS Forum so asking if what has been done is OK requires that we be told what the initial intention was. ;)
  6. melcooney
    melcooney TPF Noob!
    Jan 24, 2006
    578
    Indiana
    I took the first picture of the sunset and then added the second picture of the waves as a second layer. I think what I was trying to accomplish is impossible as the reason it looks unnatural is the pictures were taken on two different days at two different angles of the beach. No, my feelings are not hurt *Ü* I would not have asked for help in critiquing if I was that sensitive. Next time I will post the original pictures and then the outcome so I can get better help. I had found the PS files on my harddrive already merged as one layer, so to do this now would be impossible. The originals are already filed away on disk somewhere. Thank you Jeff and Hertz for trying to help!
  7. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Hertz the answer to why did you do that is always..... because i could no other reason
  8. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yea mel..... the merge doesn't quite work in this image...... the suns reflection is in a straight line as if the water is dead calm, so it doesn't look natural over the waves. It would work better if the opacity of the waves level was bought right up to cover the reflection and also give it more depth........ if you know how to layer mask, you could bring in a bit of the reflection right by the sun and blend it out........ but not the whole way out. Give it a try, hope this helps. ;)
  9. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    There are none so blind as those who refuse to see. ;)
  10. mysteryscribe
    Feb 1, 2006
    6,071
    Even worse are those who shoot the seeing eye dog.
  11. melcooney
    melcooney TPF Noob!
    Jan 24, 2006
    578
    Indiana
    Thanks Archangel...
    I'll give it a try, after all:
    that's how I learn! :D
  12. KenCo
    KenCo TPF Noob!
    Apr 25, 2006
    518
    North East UK
    I always run into trouble merging layers, this one to me doesn't look quite right BUT, why not post your two shots and let others have a go...then maybe they will explain how they achieved it. Might be of help to me also.
    Just a thought.
