Surface blur?
Discussion in 'Digital Discussion & Q&A' started by kellylindseyphotography, May 19, 2008.
  1. kellylindseyphotography
    kellylindseyphotography TPF Noob!
    Mar 26, 2008
    1,270
    Haverhill, Ma
    I'm reading this tutorial and wondering how sound it is. Is this a valid technique to use? If not, can someone point me in the direction of a great tutorial? Please and thank you :D
  2. kellylindseyphotography
    Mar 26, 2008
    1,270
    Haverhill, Ma
  3. kellylindseyphotography
    Mar 26, 2008
    1,270
    Haverhill, Ma
  4. Lacey Anne
    Lacey Anne TPF Noob!
    Mar 6, 2008
    709
    WA state
    I wish I could be helpful, Kelly, but I really don't have enough knowledge myself to answer your question. Sorry. I hope some comes along though!
  5. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    It is one way of creating such an effect yes.... if its the porcelin skin type effect you want.
    To me there are advantages and disadvantages of following such tutorials... the advantages are if you are not familiar with the methods used in the tutorial then by all means go through it and learn... you will pick up skills which you can transfere to other photoshop procedures.
    The disadvatages are, these techniques are often quite destructive to the image... surface blur is no exception... but can be used for some clients if they like the effect.
    The more you use photoshop techniques the more you can fine tune your own way of doing things in a less destructive way....
    So i would say go through it and learn it by all means. ;)
  6. kellylindseyphotography
    Mar 26, 2008
    1,270
    Haverhill, Ma
    Thank you Arch. I wondered if it was a retouching tip that "pro's" use for pocelein skin, basically. Or if there is something I can do in PS that is better?
    I liked this tutorial because it worked in layers and masks, not just opacity. And the blur seemed pretty subtle?
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    This is a slow subforum, there's no need to bump 3 times in one day.
    The final effect always depends on what your after. It looks to be by far the most detailed and over the top tutorial I have seen so far. I've done some skin retouching before but I have never added shadows or highlights to the subject. I always thought that's what makeup artists do.
    Also this is not the only way to do it. Just one of the ways. Remember that, there is no "tip pro's use" there's just "one of the methods that pros can use".
    But the most important thing is still just try it. If it gives you the right effect remember it. If you don't like it find something else.
  8. kellylindseyphotography
    Mar 26, 2008
    1,270
    Haverhill, Ma
    I bump for those that only peruse "new posts" as I do :) Thanks for the advice.
