Sweet spot of EF 70-200mm f/4l
Discussion in 'Photography Beginners' Forum' started by jamesino, Jul 19, 2008.
  1. jamesino
    jamesino TPF Noob!
    Dec 9, 2007
    115
    What is the absolute sweet spot, in terms of a focal range and aperture combination, for the Canon EF 70-200mm f/4l USM (without IS)?
    Would it be 135mm at f/5.6?
    EDIT: Sweet spot as in the area where the IQ is the highest.
  2. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    It's already an L lens, why are people so obsessed with this stuff?
    In the time it takes to do resolution charts and find out how many degrees of blah blah blah and chromatic abberation and this and that and the other...
    YOU COULD HAVE BEEN OUT SHOOTING!!
    See also: I don't know.
  3. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    On the 70-200mm F/2.8 IS USM (different lens) it is at 100mm F/5.6 I believe :p
    Maybe they are similar?
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Pro lenses, and especially pro telephoto lenses are often designed so that they are very good with a wide open aperture...as that is where they will often be used. They still might be a little better when stopped down one or two stops, as that is typical for most lenses.
    I've also heard that F8 is a very good aperture for most lenses.
    With a lens like that, I wouldn't worry about it. It will be exceptionally good throughout the range. Concentrate rather on other factors to improve IQ...like using a tripod and MLU.
70-200 f4 sweet spot
canon 70 200 f4 sweet spot
canon 70-200 f4 sweet spot
