Swimsuit models NSFW
Discussion in 'The Professional Gallery' started by jlykins, Feb 23, 2009.
  1. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Got into the new studio last week, and after a few days of painting and stuff this was the first shoot I did. These are a couple of "swimsuit models" that work for a small production company in Cincinnati. CC welcome. Almost forgot, the setup is all whitelightning strobes. a 1200 at about 45degrees camera right, a 1200 just to the camera left, and two 1200's on the background. First time using the new strobes, and man those things are powerful.
    [​IMG]
    [​IMG]
    [​IMG]
    4
    [​IMG]
    5
    [​IMG]
    6
    [​IMG]
    7
    [​IMG]
    8
    [​IMG]
  2. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,046
    80
    Kankakee, IL
    Man..... the lighting on these is too flat. No punch.
    Sorry. I can't add anything more.
    -Pete
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Not bad...but I agree with Pete, they could use more punch.
    They need more contrast, which could probably be done pretty easily with levels & curves. As for the lighting, a greater ratio between your key & fill lights might help.
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    Looks like you could also do with a flag for your lights. You appear to be getting a little washout from them.
  5. crazycreature11
    crazycreature11 TPF Noob!
    Feb 22, 2009
    73
    good shots ! :) nice angles
  6. Christie Photo
    Jan 7, 2005
    7,046
    80
    Kankakee, IL
    I wondered if it wasn't coming off the background.
    -Pete
  7. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Could have been. Main light was f8 key was f5.6 and both background lights were f11. Took a meter reading from about 4 feet in front of the background and got f11 at 1/250th. That's what I was shooting at. Next time I'm going to drop the key to f4 or maybe slightly higher. We'll see. I agree that the lighting is a bit flat. Luckily the customer was happy. That's all that really matters to me...
  8. Christie Photo
    Jan 7, 2005
    7,046
    80
    Kankakee, IL
    That sounds about right to me, presuming you mean the fill was at f5.6.
    In fact, I would expect you had the background 2 stops over the main.
    Hmmm......
    Do you keep your main and your fill the same distance from the subject?
    -Pete
  9. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Yeah same distance. I think it may have been the mismatched heads. I realized a few minutes ago that I was using a White lightning 600 as the main, and the 1200 as the fill. Ooops...
  10. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Wait, wait, wait, that shouldn't matter though. The light meter read what the output was no matter what, hmmm. I'll have to look at the setup later. Maybe pop each one again just to verify the output...
  11. Christie Photo
    Jan 7, 2005
    7,046
    80
    Kankakee, IL
    Have you ever tried having both lights with the same output, but position the fill further back... behind the camera?
    This is an old "film" approach. The thinking was "expose for the shadows, print for the highlights." This doesn't apply to digital. These days, I expose for the highlights and adjust the shadows to get the ratio I want.
    But anyway.... I still work with the main light in close and the fill light behind me just to free up the space between the subject and myself (I like to move in a lot to adjust hair/clothing). And, the light will act differently with main in close... softer, wrap-around quality, softer edge shadow. You get larger catch lights too.
    I keep the modeling light on the fill turned off so I can better see the modeling from the main.
  12. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I position the main/key light as close to the subject as possible...to make it as soft as possible (when I want soft light).
    My fill light however, is farther back...sometimes a lot farther back if I've got the room. One reason for this, is because it minimizes the catchlight from the fill.
    Also, the fill light need not be opposite the key light. The fill should be (can be) thought of as a flat wash of light that brings up the levels of everything the camera sees. It does not (or should not) cast it's own shadows for the camera to see...so it could be right above the camera or wherever works for you.
bikini nsfw
forum swimsuit
modeling nsfw
nsfw swim
nsfw swimsuit
nsfw swimsuit videos
nsfw swimsuits
swimsuit forum
swimsuit models nsfw
swimsuit models threads
