sync cables and off camera flashes
Discussion in 'Beyond the Basics' started by Skyeg, Mar 5, 2004.
  1. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    i want to use a vivitar 283 or 285 on one of those flipy bracket things that keeps the flash centered over the lens. my camera only has a hot shoe so what do i need to be able to do that?
  2. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
  3. photogoddess
    photogoddess TPF Noob!
    Feb 29, 2004
    6,253
    34
    Lala Land
    The flash brackets that I have seen mount where you would attach the camera to a tripod. You would then put the flash on the top of the bracket and use a sync cord to trip the flash. Make sure you have a long enough cord that you can flip the flash for vertical and horizontal without pulling the cord out of the camera or flash but not so long that you get tangled up in it.
  4. Chase
    Chase I am now benign! Staff Member Supporting Member
    Mar 9, 2003
    7,809
    51
    Deep in the heart of Texas!
  5. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    thanks voodoocat
    photogoddess i know how to use a bracket i wasnt sure if u could connect a camera with only a hotshoe to a flash with a sync cable...i should have worded that batter
  6. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    If the bracket already has the synch cable coming out of it, there is also an adapter that on has the hotshoe adapter where you can plug the synch cord in.
  7. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
  8. photogoddess
    Feb 29, 2004
    6,253
    34
    Lala Land
    I figured as much since that was WAY too simple. I have only used a bracket the way I described and strobes and powerpack. There are all kinds of things to attach to our cameras. Wow - more to buy and try out. :lol: Personally, I am dying to try out some Pocket Wizards. :D
  9. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
  10. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    By the way, the Vivitar 285 is a fantastic flash. I use it with all of my cameras. Very versatile, very easy to use. Better than any TTL dedicated flash I've ever used.
  11. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    i totaly agree with you ksmattfish, iv been useing nikon Sb-50DX and SB-80DX for a while and i just started using the 285 and have found that my nikon flashes are staying in my backpack alot more.
