Table top for a tripod??
Discussion in 'Photography Equipment & Products' started by Overread, Mar 11, 2010.
  1. Overread
    May 1, 2008
    23,463
    3,953
    UK - England
    Not table top tripod but rather a table top for a tripod!
    Google is being no help at all - so - does anyone know if there is such a thing as a smallish square of wood attached to a screwthread that then attaches onto a tripod? Just trying to come up with ideas for a mobile (and lightish) setup for a macro studio and a table out in the field is one idea - however most portable tables are flimsy things - so I thought what not screw a small wooden top to a tripod?
    Anyone ?
    (I'd rather not have to go DIY because I havn't got any tools nor even a shed!)
  2. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
  3. Overread
    May 1, 2008
    23,463
    3,953
    UK - England
    Ahh thanks! Sadly I can't seem to find that in a leading UK dealer, but I'll try searching around the name some more (though it seems tripod tray also commonly refers to the kinds that sit between the legs of the tripod as well
  4. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    Sounds VERY easy to make.
    I KNOW you could make one (probably a better one too) cheaper than you could buy one. The threads need to be 1/4 - 20. You should be able to find a bolt with those threads pretty easily.
    You could even make one with a built in quick release plate.
    edit
    I think I know what my next project will be, lol.
  5. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    165
    San Diego, CA (RB)
    Gorillapod.
  6. Overread
    May 1, 2008
    23,463
    3,953
    UK - England
    Ship me one when you're done Josh ;)
    Heh and yes I can envision the design quite easily; though Id probably go for a solid tripod to tray mount rather than a quick release setup. Don't see any major reason for it to be a quick attach/remove setup and it means I won't end up accidentaly overloading the tripod head (you know like leaning on it or something).
    Trick would be working out the best size to have the table area at so that its stable and can take an edge weight (chances are some glass will held over one edge with a moth on it and who knows what else above it ;)).
    Dom - nope I can't see a Gorillapod helping here
  7. Dominantly
    Jul 30, 2009
    3,032
    165
    San Diego, CA (RB)
    I've read it a few times now, and I'm not sure I can picture what you're looking for.
  8. Overread
    May 1, 2008
    23,463
    3,953
    UK - England
    Have a look a the link USA showed - a table/tray top that fits onto the top of a tripod instead of a regular tripod head (or in addition to if you make one with quick release). The idea being that you have a smallish table top surface supported by the tripod legs.
  9. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    If (when ... ;)) I were making it, I would figure the area based on the FOV I would expect to need while using it.
    Should be relatively easy to calculate - what lens will you be using, and how far away will it be? AoA (Angle of Attack ... don't know how else to describe it, lol) would be a factor too.
    Add a few inches just in case.
  10. Dominantly
    Jul 30, 2009
    3,032
    165
    San Diego, CA (RB)
    I see. Is this so you can put bugs on it out in the field, and have your way with them?
    Getting down on the ground doesn't work for ya?
  11. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    :lmao: :lol: :lmao:
  12. Overread
    May 1, 2008
    23,463
    3,953
    UK - England
    Field of view for me then would be - hmm - a few cm at the very most ;)
    It's more to hold the setup as well - so would probably end up far larger than what is needed for a macro setup. and would probably be supporting a lighttent/box at the very least.
    And yes Dom its so I can have my wickied way with bugs ;) - but its also semi serious. For started as well as pretty arty shots I want to get good record shots, so I need at least a flat surface that is clean (not muddy) to capture those images. Then I also want to get the underside of the insect as well. Thus far the best I can come up with is the idea of using a glass sheet or UV filter and holding the setup up high (ok not that high) and shoot from below - most moths do stick rather well, but if I can have hte moth in a single position ontop of the glass for the first shot and then simply shift to shooting under it means less disturbance which means less chance of the moth flying off
delvcam utt-1 universal tripod tray
diy table top tripod
diy table tripod
diy tipod tray
diy tripod table
homemade table out of tripod
homemade tripod tray
tripod table attachment
