Taking photos of 4x6 prints?
Discussion in 'Beyond the Basics' started by Big Mike, Aug 8, 2005.
  1. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Here is the situation. I want to get digital images of a bunch of photos to put into a slide show for my wedding. The quality does not have to be great....just good enough for projection onto a large screen.
    I'm sure I could scan the prints, but the only scanner I have access to is fairly slow and I'd have to do it at work...which I might not have time to do. I was thinking that I could probably get decent results if I set up a make shift copy stand with my 20D. Once it's set up...I could digitize lots of photos in a fairly short time.
    Has anyone tried this? My main concern is lighting. Obviously on-camera flash would be a bad idea...as it would cause reflections. I might even need to have the prints under glass to ensure that they are flat...which would add to the reflection problem. I might use an off camera source of light...but I'm not sure of that will make the prints look uneven. Maybe a couple of lights as in a small studio set up...maybe a light box type set up?
    I want to do this as quick and easy as possible...otherwise I might as well scan them.
    Any ideas?
  2. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    Well...my boss uses that technique as you get better quality than with a scanner, next time I see him ill try and ask him :)
  3. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    I haven't does that before but have you considered places like Costco or those kiosks you'd find at pharmacies/supermarkets?
  4. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    It been a long time but I have done the copy stand approach before (sort of), us a tripod with a removable centre rod. Simple reversed rod so camera hung between the legs. And lighting was a problem. IMO you would need to shot in RAW and would need to edit all the shots in PS.
    IMHO the easy way to go is to buy a new and better scanner
  5. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Thanks...I have been thinking of just getting a new scanner...they are pretty cheap these days.
  6. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    Yeh, scanners are going very well now...
  7. fadingaway1986
    fadingaway1986 I Burn Easily :(
    Feb 4, 2004
    1,449
    9
    Queensland, Australia
    Get a scanner :)
    Or you could take your negs into a shop and have them scanned.
