Tamron 24-70 f/2.8 NIKON F-Mount
Discussion in 'Nikon Lenses' started by HeldInTheMoment, Oct 24, 2017.
  1. HeldInTheMoment
    HeldInTheMoment No longer a newbie, moving up!
    Jul 27, 2015
    255
    33
    Vermont, USA
    Anyone else have this lens? If so, do you experience soft images in low light?
    I mean, I know soft light = soft images...but all my other lenses are tack sharp when the 24-70 seems to be off sometimes.
    • Like Like x 1
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,262
    15,117
    USA
    Low light can mean 1) wide apertures like f/2.8 and 2)slow shutter speeds and 3)higher than normal ISO setting levels. All three of the numbered issues can contribute to "soft" images. MANY zoom lenses are NOT very good at f/2.8...they often have a noticeable improvement at f/4.
    If other lenses do better in the same,m exact situations, then perhaps there is an issue with the lens? Maybe the focusing is not spot-on? Perhaps the issue could be better seen and evaluated if you post a photo complete with EXIF info, so people can look at the problem and literally 'see' what you mean.
    • Like Like x 1
  3. nerwin
    nerwin Been spending a lot of time on here!
    Jan 31, 2015
    3,171
    1,065
    Vermont
    Can you fine tune autofocus on third party lenses?
    You have the D500 which has the new automatic AF fine tune tool. I'd suggest doing that first if it works with third party lenses and see if that helps.
    But like Derrel said, shooting wide open will often result in softer images.
    • Like Like x 1
  4. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,419
    4,429
    NoVA
    mine's pretty darn sharp at 2.8
    • Like Like x 1
  5. HeldInTheMoment
    Jul 27, 2015
    255
    33
    Vermont, USA
    I fully understand wide open gets soft images, but even at f/4 sometimes I see softness, just not as often. Sometimes it locks focus (as per the AF point) on the subject (i.e. a person) then later in post I see it focused on the background (trees over 100 yards away).
    I know the D500 has the AF Fine Tune and I tried that; though, to test it I ran it several times. Same location, same target, same light, same settings, on a tripod with remote shutter....I found the settings to change every time so I set it back to default.
  6. HeldInTheMoment
    Jul 27, 2015
    255
    33
    Vermont, USA
    Mine is too, SOMETIMES...my other Tamron lenses are 100% sharp (or I know I messed up).
  7. nerwin
    Jan 31, 2015
    3,171
    1,065
    Vermont
    Sometimes it's sharp at 2.8? Sounds like a focus problem or you move just enough to make it look soft. I don't know man. Maybe you just got a doozy.
  8. Destin
    Destin Been spending a lot of time on here!
    Sep 11, 2010
    3,130
    792
    Western New York
    Can you post examples of what you mean? This would help us to trouble shoot. Also, which version of the lens do you have? The old VC model or the new G2?
  9. shadowlands
    shadowlands No longer a newbie, moving up!
    Oct 9, 2009
    1,248
    198
    Houston, Texas
    If it makes you feel any better my "Nikon" 24-70 F2.8G is in the shop.
  10. Solarflare
    Solarflare No longer a newbie, moving up!
    May 24, 2012
    2,637
    326
    No lens has ANY idea how much light is falling through it.
    Thus no, no lens ever gets soft from a certain amount of light.
    What you get in low light is little light to work with, which introduces:
    1. High ISO on the sensor, thus noise
    2. Slow shutter speeds, thus camera shake
    3. and movement blurr
    4. Possibly also misfocus due to the autofocus system having issues locking on correctly
    5. Maybe more ? I cant think of any other factor right now.
    All of which introduce correspondingly lowered image quality.
    Not a softness of the lens, though. These effects all look distictively different from lens softness.
  11. goodguy
    goodguy Been spending a lot of time on here!
    Dec 5, 2012
    5,542
    1,113
    Toronto Canada
    I own the Nikon 24-70mm 2.8G, my second shooter has the Tamron 24-70mm 2.8 VC (Original version) it is my unscientific estimate that his lens is sharper then mine by around 10%-15% across the board, I am super impressed with it.
    Only flaw is that its slower to AF then my lens and while its fast enough to AF for all reasonable needs my lens is much faster then this Tamron.
