Tamron lenses
Discussion in 'Beyond the Basics' started by Djurchicprelude, Aug 26, 2005.
  1. Djurchicprelude
    Djurchicprelude TPF Noob!
    Aug 17, 2005
    15
    Tamron lenses, are they good or crap? specifically for a nikon d70s? thanks
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Crap.
    Ask a silly question....
    Some people quite like them, but then they've probably not done a back-to-back test with Nikon top glass or they don't have the budget. Either way, they are budget lenses and the results are entirely personal opinion - some people here like Holga lenses for example as they produce a pleasing soft image.
    Rob
  3. Bibos
    Bibos TPF Noob!
    Jun 22, 2005
    39
    Innsbruck, Austria
    as with (almost) all of the manufacturers, some are very good, and some are crap. You should post which lens you had in mind specifically, then we can probably help.
  4. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    I think Tamron havent chipped their old lenses for digital SLR's, and charge you to chip them, so id say dont go with it...and why type in BIG BLUE WRITING?
  5. montresor
    montresor TPF Noob!
    Aug 22, 2005
    289
    Cleveland Hts., Ohio
    I bought a budget Tamron 70-300 (renamed "ProMaster" and sold through a nat'l camera store chain) which interfaces nicely with my Canon EOS film SLR; the salesman said the lenses have also interfaced well with the Canon digital SLRs. I'm not such a world-class photographer (I'm pretty awful, in fact, if you consider my good/bad photo ratio) that I have to have the ultimate lens. To me what's in front of the lens that's more important. One advantage, I got the big honkin' thing for $179. Branded Tamron's are way more than that, but still attractively priced well below the top stuff.
  6. montresor
    montresor TPF Noob!
    Aug 22, 2005
    289
    Rob, re: Holga lenses, I found a 180 degree rule applies: any Holga shot I take that I think is going to be just wonderful turns out to be anywhere from bad to completely incomprehensible. Conversely, shots I take that, upon clicking the shutter, make me think "Now why'd I do that?" seem to turn out better than good. This applies only to the Holga....
  7. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I would agree with this. There are plenty of people who believe if it's got "Canon" or "Nikon" stamped on it that it's got to be the best, better than all the rest, but they put out their share of mediocre glass too.
  8. Djurchicprelude
    Aug 17, 2005
    15
  9. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    well, both of those lenses will work fine if you use them correctly, but if you want to get technical about it, they are both slow lenses, meaning that they do not have very wide apertures and you cannot get as high shutter speeds as you could with 'faster' lenses. they are a bit soft sometimes, but that can be remedied by stopping them down a stop or two. i've heard that 70-300 has pretty bad autofocus, it hunts and is slow. so there you go. there are a few GREAT tamron lenses though, if you want to buy them seperately.
  10. Djurchicprelude
    Aug 17, 2005
    15
    so the whole 3fps that you could do with this camera you wont be able to do cause of the lenses?
  11. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    As thebeginning pointed out, the autofocus is quite slow, so if it tries to autofocus for each shot then 3fps is pretty unlikely. I have a similar problem with a film camera that can supposedly manage 3 shots per second; this is normally only possible when I switch off autofocus and focus manually instead.
  12. thebeginning
    Jan 10, 2005
    3,795
    30
    Texas
    no, you can still do that, but you wont be able to get as fast of actual shutter speeds as you would if you had a lens with a larger maximum aperture size.
    let's say you bought a 50mm f1.4 lens. the smaller the f number, the more light that can get into the camera, and the faster your shutter speeds can be.
    an example: at f2, you might get a shutter speed of 1/1000 seconds, while at f5.6, you would get a much slower shutter speed of 1/125 seconds. This only really matters if you will be taking pictures of fast moving objects.
tamron crap
