Technical Question
Discussion in 'Beyond the Basics' started by Rod-UK, May 22, 2005.
  1. Rod-UK
    Rod-UK TPF Noob!
    Mar 4, 2005
    133
    Exeter Devon UK
    This is a view in which three pics are carefully (!!) put together to provide the panorama,
    The camera was mounted on a levelled tripod and panned to provide slightly overlapping photos. the prints were then re-photographed and the joins blended in PS, the 400mm x 150mm print looks quite good (even if I say so)
    The included angle from right to left is about 120 degrees, the horizon is about 10 - 15 miles away and is distinctly curved
    Question;- Is this curvature a function of the lens and camera, or is it a true reflection of the curvature of the earth.
    __________________
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Well first off - what focal length did you use? If it was a wide then some curvature might be attributable to lens distortion.
    The bulk of the curvature is probably to do with perspective and not having the tripod exactly square on to the horizon. Did you use a spirit level to set it up?
  3. pursuer
    pursuer TPF Noob!
    Aug 8, 2004
    1,397
    40
    Canada
    I would say neither, it is caused by the difference in angle of each shot and can be corrected in PS during stitching.
    edit:
    Hertz you posted while I was typing, im just too slow, lol.
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    If you look at the upper left corner you can see what looks like to me to be the top edge of the original exposure sloping down to the left. I have to think that it's lens, level, and/or software.
    Don't we have some airplane folks on TPF? How high do you have to be before you can see the curve of the planet?
  5. chris
    chris No longer a newbie, moving up!
    Jun 20, 2003
    276
    25
    Scotland
    To produce panoramas with minimum distortion use a normal to long focal length and big overlaps. Using a 50mm lens and 35mm camera I would rotate the camera no more than 30 degrees between shots and only use about the centre one-third of each frame. You definitely want to avoid wide angle lenses because they are generally more prone to distortion at the edges than normal or moderate telephotos. You also need to ensure that the camera is leveled in all planes.
    To further minimise any distortion, the axis of rotation of the camera should pass through the optical axis of the lens and be a distance equal to the focal length of the lens in front of the film plane (for a lens focused at infinity).
    All of these help to reduce distortion and help a stitching programme produce the best results
  6. Rod-UK
    Rod-UK TPF Noob!
    Mar 4, 2005
    133
    Exeter Devon UK
    Thank you all for the comments. One way or another you all seem to think the problem lays with the use of the camera.
    When the opportunity comes about I will have another go at this panorama, taking on board all that has been said.
    Cheers
    _______________
