Technical vs working knowledge
Discussion in 'Photographic Discussions' started by D-50, Nov 5, 2007.
  1. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Just wondering what people feel about knowing the nuts and bolts of photography,i.e. what you would learn in a classroom vs just knowing how to take properly exposed and composed shots. I do not necesarily know exactly what is going on inside my camera when Im shooting but I know when a shot will need to be over or underexposed, furthermore I really do not understand the technicalities of metering although I understand the differing results I get when I change my metering mode on my camera. I realize I did not ask much of a question but any thoughts on this topic?
  2. Davec223
    Davec223 TPF Noob!
    Oct 13, 2007
    33
    South Coast UK
    I feel that to know the technical stuff helps you take better pictures i.e DOF shutter apperture and iso relationships, what metering to use etc etc. you can get by by not knowing and it will be a bit hit and miss with a lot of trial and error until you get the result you want, but do you really understand what you have done to get the result and could you repeat when you want a similar end result in different circumstances? this is where the tech stuff will help all of it fall into place so that you can get the results that you want with you being able to concentrate on what you are photographing rather than the camera.
  3. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Of course I have what some might call an elitist opinion on the matter.
    Great photographers have keen senses of technicality and creativity. Technical aspects can be learned. Not by all, but my most. Creativity...well you've either got it or you don't. If you learn all the technical stuff well and still have a lot of difficulty making good shots, you'll save yourself a lot of disappointment by giving up your dreams of being a great photographer. That doesn't mean you ought to quit altogether.
    I know it sounds harsh, but I personally know a few people who are technically phenomenal...more so that I might ever be. But after shooting literally for decades, they gave a good deal of it up. Now they see it as sort of a duty to impart all their technical knowledge to other people. I think it's really cool, actually. I'm not saying that they should have given it up, in a judgmental way. People can do what they like.
  4. What I find the most impressive about "the old masters" is that the equipment they were using was so finnicky and unique that they had to be highly technically skilled and creative at the same time. A few of them built their own cameras, but all of them pretty much had to be able to fix them. If you're out in the field - and I mean way out - Spanish Civil War, Morocco in the 1950s, the Wyoming wilderness in the 1940s, Oklahoma in the 1930s... you couldn't just walk into a store and get some booger-clerk to honor your warranty. You had to fix it.
    And that's just making the exposure. What did AA say? "The negative is the score, the print is the performance." They had to do all the developing, heck they often had to build their own projector head.
    I am fascinated by the technology, and by the processes. It goes into a vast moist, fertile soil which feeds the little flowerbed of knowledge that I'm cultivating. I'm not sure I'll end up with a prize-winning rose, but at least I'll get a fat pumpkin out of it.
  5. The Phototron
    The Phototron TPF Noob!
    Jun 26, 2007
    948
    What you are concern with is two aspect of learning: knowing the principles and applying them (what you call working knowledge).
    You could grasp just a very vague idea of a principle, and still be able to make use of it (i.e. apply it by actually taking pictures). But not to the full extent, so you have to guess on aspects you do not understand, which means less control. However, even if you know the principles well, you still need to know where and when to apply them, because there are many principles. Your mind won't be able to process them all when you first try to take a picture. For example, you might be caught up in framing the picture that you forget to meter, or you remember that but forgot rules of third, etc. It is overwhelming for your mind to apply all that information at first. With experience, applying these principles will slowly become intuitive so you have more control over how your picture will look like, to a point that your visualization is the outcome.
    In your case you know darker picture means underexposed and lighter pictures mean overexposed. That is part of the technicality of metering. You have to know what is dark and what is light. Of course there's a lot you still don't know, where to meter, how to compensate, the relationship among aperture, shutter speed, and ISO. Because of your very partial understanding of exposure, you compensate by guessing. Which works to an extent, but it's very inefficient. You are giving up control to probability by not fully knowing the technicalities.
    Edit: Creativity can be learned/engineered when science gains a complete understanding of the technicality behind the mind. So they can know what would appeal to it as fascinating and what repulsive. :>
  6. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    I agree with the idea technical knowledge never hurts but what i was getting at is the idea that not knowing exactly what is happening inside the camera does not necessarily hurt you, things like DOF, shutter speed, iso, framing, exposing, taking the angle of the light source into account, and metering are second nature to me, when I look through the viewfinder allthese things are already taken care of and I never stepped foot near a classroom. I can typically get the shot right the first time regardless of the circumbstanes, I do run into trouble when setting up lighting inside though and this is where technical knowledge probably comes in great. I try to read as much as I can about photography but I have found learning through doing is a great way to learn you just need to be concious of what you are doing and not just shooting without purpose..... I also agree with the statement technical knowledge does not make you a great photographer. You could tell me exactly how a camera works but still could not take a great picture if you do not have an eye for it.
  7. The Phototron
    Jun 26, 2007
    948
    Technical knowledge is not exclusive to classroom learning, books, or researchers. Through experience you can be aware of technical knowledges, you just won't be able to identify them in technical terms. For example as you take pictures, you notice patterns of combination of shutter speed and aperture and the lighting quality that get you a good picture. As you notice these patterns you create your own theories of how to use the camera. The only difference between your theory and ones taught in classrooms, is that your theory is less organized and less coherent.
    Aperture, shutter speed, and ISO are implications of what is going on inside the camera. So by understanding aperture, shutter speed, and ISO you know indirectly how the camera functions.
    To answer you question, technical knowledge is crucial, because it helps you predict how the camera settings will achieve your visualization. But you don't need to learn it directly, you can learn it by trial and error and know them in your own words, and you don't need to learn all of it. But it definitely won't hurt you to know more unless it distracts you from learning composition.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    You need only enough technical know how to take the picture you want to take in your mind.
    I am somewhat against learning an art in a class. They seem to go beyond telling how to take a picture and start telling what the picture should look like. At least here anyway.
  9. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    The elements of design in art or composition in photography have not changed in the last half century or more, so I think one needs to be slightly delusional to think that one can totally change or ignore composition and be either successful or artistic in photography.
    skieur
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    You can make make good pictures but not great pictures without creativity, but without any level of technical proficiency, no amount of creativity will be possible to express and no pictures of any acceptable level of quality will come out at all.
    This is very much a chicken or the egg situation, IMHO.
  11. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    If it's something you want to learn, you'll have to get an education one way or another. Which environment do you learn better in; structured and planned, or self initiated study?
  12. Jestev
    Jestev TPF Noob!
    May 24, 2007
    143
    Dallas, TX, USA
    I think that knowing the technical processes behind the final image is really important to the way I view photography as an art form. It enables me to know exactly what lens would work best in what situation, what this f-stop is going to do to DOF etc.
    Of course, there really is no replacement for experience in the field. You could know everything about how and why something works, but if you don't have experience and creativity it won't matter.
knowledge of vs working knowledge
proficient vs working knowledge
proficient vs. working knowledge
technical knowledge photography
working knowledge of html
working knowledge photography
working knowledge versus
working knowledge vs
working knowledge vs proficient
working knowledge vs technical knowledge
