Teleconverter
Discussion in 'Photography Beginners' Forum' started by redtippmann, Jul 27, 2009.
  1. redtippmann
    redtippmann TPF Noob!
    Aug 19, 2008
    706
    6
    Athens, Ohio
    I was looking into a teleconverter for my 55-200 lens. I dont know what brands are good or what I should look for. I know that it will decrease the quality and all that but I just need a little more range.
    I looked at the Nikon brand one but that is $500 which at that price I might as well buy a 70-300mm.
    So any suggestion? Thanks!
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Kenko 1.4X Teleplus Pro 300
  3. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    When I get my 70-200 nothing will go on it other than a Nikon teleconverter. I have used other brands in the past, and none of them work as well. A 1.4 won't make much of a difference in your zoom range, but a 1.7 and 2.0 might suck up too much light to work well on that lens. I would get the 70-300, or save up for the 70-200/teleconverter combo.
  4. KmH
    Apr 9, 2009
    40,565
    5,548
    Iowa
    A teleconverter will decrease the apparent aperture/speed. 1.4 stops with a 1.4x teleconverter and 2 full stops with a 2x teleconverter on an already somewhat slow lens.
    Stepping up to the 70-300 you don't lose any aperture/speed.
  5. tirediron
    Jul 8, 2005
    40,936
    12,434
    Victoria, BC
    Yes, one. Don't.
    TCs work best on prime lenses; less so on zooms. You'll be much better off buying the 70-300 (BTW, Nikon TCs will NOT work on anything but their pro glass) as you'll not lose the 1.4, 1.7 or 2 full stops of aperture.
  6. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    :thumbup:
    You pretty much need to start off with good glass in order to lessen the degradation of a TC. I have a 70-200 2.8, and have used a TC14EII on it.....while the quality was still acceptable, the difference was very noticeable to me.
    I modified my TC (see below) so I could use it on my older 500mm f/4P, which gives me a 700mm f/5.6 with very little degradation, other than you had better keep it mighty still.
    http://nikonpages.heymanphotography.com/tcmod/
  7. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    :thumbup: + 1
    Before you buy a TC I would suggest that you go to a good photography shop with your lens and try them out. Look at the results on your computer and decide if you are satisfied with the quality of the photos it will produce. The best quality is only going to come from a top quality TC added to top quality glass. It's just the nature of the beast.
