Test Portraits...
Discussion in 'The Professional Gallery' started by Holly, May 14, 2006.
  1. Holly
    Holly TPF Noob!
    Oct 2, 2005
    1,143
    7
    Ok Corinna yours came out A LOT better then mine..
    NOT sure what is going on here..
    These were taking with a window on EACH side...
    F3.6 (lowest it went) and Shutter 1/6 ISO 100 and STILL very very BLOTCHY..
    [​IMG]
    [​IMG]
    What am I doing wrong?
  2. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    Turn your ISO up to 400, zoom out (this will let you use a wider aperture), get close (to compensate for the loss of zoom).
    This should get your shutter speed up a bit
  3. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    1/6 for a child's photo is way too slow. You can't do that.
    A) it is hard for anyone to keep the camera still at that slow speed and
    B) it is hardest for children to sit still during "so long".
    Yes, it is only a fraction of a second, but a long fraction.
    So I would think the blur in the first is from the moving child and the blur in the second is camera shake.
    If you want to take indoor photos, you must push the ISO, then you better not zoom (a long focus requires a lot more light than a shorter one), and you should not go any much lower than 1/60. I think........
  4. Holly
    Holly TPF Noob!
    Oct 2, 2005
    1,143
    7
    OK... Ill give those a try to see.. ILL Try this NEW Tripod too!! Mothers day gift WOO HOO
  5. Holly
    Holly TPF Noob!
    Oct 2, 2005
    1,143
    7
    Ok.. So here is the thing.. I Tried it *with out the pod* at the moment on a shutter speed of 1/60 and tried 1/100 and then 1/125..
    The higher I go the Darker my images are...
  6. LaFoto
    Feb 1, 2004
    34,813
    817
    :scratch: ???
  7. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    Because you're not adjusting your aperture inline with your shutter speed.
    The amount of light that has to hit the sensor is the same no matter what shutter speed you use. But increasing the shutter speed decreases the mount of light, so you have to compensate for this by putting the aperture wider (lower number). Vice versa, if you close down the aperture (higher number) then you need to lengthen the shutter speed.
    Does your camera have aperture priority? If so, set it to this mode, select the smallest number you can and the camera will select the shutter speed for you. See if this shutter speed is any good or not
  8. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
  9. Holly
    Holly TPF Noob!
    Oct 2, 2005
    1,143
    7
    K... I tried the app thing.. It works better kind of.. I Guess.. Its more BRIGHT, but with it even set on 400 ISO its still a bit blurry.. I am guessing this is just one of those point and shoots...
  10. LaFoto
    Feb 1, 2004
    34,813
    817
    But you take the clearest of stair-steps of flower pics with this same point and shoot. So why would your portraits NOT become as crisp and clear? THAT cannot be the reason. How near do you get to your son? Do you still use the zoom?
  11. Holly
    Holly TPF Noob!
    Oct 2, 2005
    1,143
    7
    My flowers and steps are outdoors.. and they are usually done on Automatic.. I have been doing my portraits on Manual settings to learn those..
  12. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    You need more light. I can't tell how close you are to the window, but you need to be right next to it, when lots of sunlight is coming in :)
