Thats the "proper" way to save a photo?
Discussion in 'Beyond the Basics' started by sincere, Jun 7, 2009.
  1. sincere
    sincere TPF Noob!
    Jan 5, 2006
    475
    Berlin
    When i say proper, i mean in a format with the least quality loss. I dont know what other infos you would need. Also, when saving in Photoshop under "Save for web & Devices", what is there to consider?
  2. Moglex
    Moglex TPF Noob!
    Jun 13, 2008
    578
    Whitstable
    Saving in TIFF should result in a lossless save.
    JPeg will save with varying degrees of compression and thus varying degradations in quality.
  3. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    For photos I now use the following saving methods:
    1) I shoot in RAW mode so I always have an untouched (no edit) version of every shot. If you shoot in JPEG always copy each shot you going to edit first into a new folder - that way you always have an unedited version of each shot you have taken - it also have important implications which will become clear later.
    2) When you haved edited the shot you have a choice of saving modes:
    a) Photoshop PSD file - this is a good format since it saves all the layers of your edit intact - so if you come back to edit all the layers you used first time are still present. They can be quite large save files though
    b) TIFF - this is a lossless save formate (no data is ever lost from the file) and like the above they are again larger file sizes. They do save layer details as well
    c) JPEG - lossy save format - which means each time the image is saved some data is lost - it does not take many saves before you can start to get image degradation. This is even more apparent if you then try to edit the photo. This is why you always copy the original and edit the copy. The files are however a lot smaller than the above making them good for the internet.
    d) Save for web - JPEG format which also drops all EXIF details as well as a few other things so that the image file is as small as possible - you can even specify a filesize (at a possible loss of image quality) to keep filesizes down.
    Myself I Save each edited photo as a PSD file - then I make another folder into which I put smaller resized JPEGs for internet upload.
  4. yogibear
    yogibear TPF Noob!
    Oct 20, 2008
    165
    Portland, OR
    Great question! I usually save Tiff but I have often wondered if there is any advantage to saving as a PSD file. Thanks to both of you.
  5. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    I download the raw files as .DNG. I convert my edits to .TIFF and .JPG.
    Love & Bass
  6. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Hmm. No one's mentioned PNG. PNG can be a good choice for the web, particularly web design if/when you need a relatively small file but also need to preserve transparency (JPEG doesn't preserve transparency).
    craig, is there a particular reason you convert to DNG? I know Adobe says they have plans to make it an open format, but until they do, I worry they might pull a Microsoft (MS said that their new xml-based formats like DOCX and PPTX would be open formats, and we have yet to see such a thing).
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    PNG has the two downsides that it is incredibly slow to process (much slower than TIFF with LZW compression) while providing no size advantage, and unlike TIFF with compression does not save layer data or colour profile information as part of its standard spec. A big downside for those who shoot and save in AdobeRGB for whatever reason. PNG really shines where a reduced colour spec is required such as web graphics but is not so hot for photos.
    DNG IS an open spec. That is the point, otherwise it would not exist. The complete spec for version 1.2 can be downloaded from adobe for anyone wishing to implement it http://www.adobe.com/products/dng/pdfs/dng_spec_1_2_0_0.pdf
    Also on that note Save for Web and Devices tips:
    - Tick Convert to sRGB ALWAYS! There is rarely a situation where you want to give someone a lower quality version of your file and don't wish it to be in sRGB. This is a safeguard for forgetting colour management.
    - Set preview underneath to : Document Colour. (important if you use a calibration system like Spyder2 which applies a colour profile to your monitor or it won't output the correct image to your display).
  8. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    I shoot in RAW and keep all the RAWs in an folder.
    I have a working subfolder under each shoot where I save a high res JPG version of the best "keeper" shots that I have edited, corrected and so on. I typically send this to the client/model. I also have a second folder called web where I resize the JPG to a web format.
    So.... shoot and store in RAW, save once in high res JPG and again in resized JPG
  9. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    Well I'll be. Thanks Garbz. Any idea on when camera manufacturers are going to start using DNG though? o_O
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    DNG support is coming but very very slowly. :(
    So far only Leica, Pentax, and Hasselblad have native DNG support.
  11. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    Figures that Hasselblad would jump on it. I doubt anyone would forgive them if they weren't at the forefront. *kicks Canon* My 450D would like a firmware upgrade boys!
  12. sincere
    sincere TPF Noob!
    Jan 5, 2006
    475
    Berlin
    Garbz (or else), whatabout the quality option when it comes to saving pics?
    BIlinear?Nearest neighbour, bicubic? Bicubis smoother and sharper? What to pick=?
