- Joined
- Sep 2, 2005
- Messages
- 14,455
- Reaction score
- 3,328
- Can others edit my Photos
- Photos OK to edit
I always enjoy a good photoshop challenge.
Obviously a big part of your core problem (aside from composition) is that you focused on the rock with a relatively shallow depth of field, but I tihnk you know that.
This isn't perfect, but honestly I don't think the image is actually recoverable... it does, however, show the potential of what can be done to fix a missed image.
If I put a bit more work in it could have been better, but this was about 5 mins effort just to see.
What I did:
A circular polarizing filter can also help a bit on colors and harsh glare in bright sun conditions, but I don't think this was really a problem in this case.
What I did:
- Used a color range to select the sky, feathered the selection, and saved it.
- Copied in a decent sky from another shot I had lying around as a new layer.
- Loaded the selection and feathered it slightly, created a layer mask to only reveal that part of the sky.
- Messed around with the opacity of that layer so it wasn't overly blue for the scene. (this also helps obscure the fact that it was a pasted in sky)
- Used a paintbrush to clean up the edges of the layer mask a bit to make the fact that I pasted a sky in less obvious.
- Did an unsharp mask to reduce the haze (20% sharpening, 250 pixel range, 2 threshold)
- Desaturated the image just slightly.
