The right place at the right time
Discussion in 'General Gallery' started by andre_gwynt, Nov 14, 2004.
  1. andre_gwynt
    andre_gwynt TPF Noob!
    Feb 29, 2004
    124
    On the road in Europe, Middle East or Africa.
    [​IMG]
    On my way to Sweden I had time to go to the end of the B pier at Sundown to catch this plane coming in. The tails of the other planes finished the picture. It is now my welcome banner at http://www.thewindowseatjournal.com
  2. John E.
    John E. TPF Noob!
    Jul 19, 2004
    2,221
    13
    Living in Kootney time
    I like it, the sky colors are different. Saw your website, very good use of the image. Jeeze you sure get around.
  3. Nytmair
    Nytmair TPF Noob!
    Nov 25, 2003
    2,388
    8
    Buffalo, NY
    what shutter speed did you take that at to get the plane flying pretty clear... i would think it would be somewhat blurry with the lower light.
    I like the shot though, and the flying plane definately makes it for me.
  4. andre_gwynt
    Feb 29, 2004
    124
    Here is all the info on the shot,
    Make: Minolta Co., Ltd.
    Model: DiMAGE 7i
    Description: DCF 1.0
    Date modified: zondag 7 november 2004 17:30:55
    Orientation: Top / left side
    X-Resolution: 72/1
    Y-Resolution: 72/1
    Resolution unit: Inch
    Firmware version: Ver.1.11e
    YCbCr-Positioning: 1
    Date taken: zondag 7 november 2004 17:30:55
    Date digitized: zondag 7 november 2004 17:30:55
    Exposure time : 1/180
    Exposure program: Normal
    Exposure mode: Auto
    Exposure bias [EV]: 0,0
    F-Number: F4,5
    Focal length [mm]: 50,48046875
    35mm focal length [mm]: 199
    ISO value: 100
    Max. aperture: F3,4
    Digital zoom: Off
    Subj. distance range: Distant view
    Flash: Not fired, compulsory flash mode, return light not detected
    Metering mode: Multi-segment
    Gain control: None
    Light source: Unknown
    White balance: Auto
    Contrast: Normal
    Saturation: Normal
    Sharpness: Normal
    Brightness: 7,30
    Colour space: sRGB
    Subject area: 49152
    Custom rendered: Custom
    Subject program: Standard
    Image width: 2560
    Image height: 1920
    Components configuration: YCbCr
    Compression: 6
    X-Resolution: 72/1
    Y-Resolution: 72/1
    Resolution unit: Centimeter
    JPEG offset: 13186
    JPEG size: 2129
    Index: R98
    Version: 0100
    Focus distance [m]: Infinity
    Focus mode: AF
    Focus area: Wide
    AF position: Right zone
    Spot focus point X: 1280
    Spot focus point Y: 960
    Color: Normal color
    Color filter: 0
    B/W filter: 0
    White balance: Auto
    Contrast: Normal
    Sharpness: Normal
    Saturation: Normal
    Red balance: 1,559
    Green balance: 1,000
    Blue balance: 1,387
    Brightness: 7,38
    Flash mode: Fill-flash
    Flash: Not fired
    Flash (internal): Not fired
    Flash compensation: 0
    Macro: Off
    Digital zoom: Off
    ISO setting: 100
    Exposure mode: P
    Exposure compensation: 0
    Focal length [mm]: 49,33
    Shutter speed : 1/181
    Aperture: 4,8
    Film speed: Auto
    Subject program: None
    Max. aperture: 3,4
    Model: DiMAGE 7i
    Sequence length [min]: 1
    Sequence number: 2
    Interval mode: Still image
    Version: MLT0
    Drive mode: Single
    Bracket-Step: 1
    File number memory: Off
    Last file number: 0
    Folder name: Standard form
    DEC-Position: Contrast
    Image quality: Fine
    Image size: 2560x1920
    Date taken: 7-11-2004
    Time taken: 17:30:55
