the rule of thirds?
Discussion in 'Photography Beginners' Forum' started by jdmwannabee, Nov 21, 2008.
  1. jdmwannabee
    jdmwannabee TPF Noob!
    Nov 17, 2008
    37
    so i have been hearing alot about the rule of thirds and i have no idea what it is, so i start searching for it and all i can find are people saying use the rule of thirds, or you didn't use the rule of thirds, or look up the rule of thirds, so i am finally asking for help, can someone please post a link to a thread explaining the rule of thirds! thank you so much! :mrgreen:
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
  3. chall33
    chall33 TPF Noob!
    Nov 11, 2008
    42
  4. jdmwannabee
    Nov 17, 2008
    37
    Thanks alot guys.
  5. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    once you understand what it is, its pretty easy to do.. and its not hard to understand either.. just dont centre your pics..
  6. Jeremy Lim
    Jeremy Lim TPF Noob!
    Oct 23, 2008
    66
    Vancouver, British Columbia, Canada
    Once you learn the rule of thirds, don't constrain yourself to it. While it is a good thing, if you think a shot would look better a different way, don't be afraid to try it out. Same goes with flat horizons. Leaning the angles helps makes things bigger than they actually are at times.
  7. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Strange... the TS says they were "searching" for the rule of thrids and they still didn't understand... but when I google the "rule of thrids" all I end up with is endless exact descriptions of what it its.
    Seriously, learn to search better.
  8. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    Read a book on composition.
  9. Davey Jones
    Davey Jones TPF Noob!
    Nov 5, 2008
    31
    the whole thing revolves around something called 'the golden measrure' or 'the golden mean'.
    Troughout nature u can find examples of certain repeating geometry in all things.
    it starts with a ratio of 1:1.618.
    You can find this all around you, for instance the ratio of the sise of your upper arms
    compared to your lower arms, same for legs, the ratio of trunks as they form along the length of a tree etc.
    from this ratio nature derives certain forms like spirals like the ones u can see in
    tornadoes, spiral galaxies, the spiral forms in the pattern of seeds on a sunflower
    etc etc etc.
    so the thing is nature is prone to produce things in a certain ratio, and as a result
    we are more familiar, more comfortable and ultimatly more attracted to things that
    adhere to these ratios and forms.
    artists like da vinci took advantage of that and would allways apply this ratio
    to the things they painted so as to make them look more natural and appealing.
    the rule of 3rds is the photographers way of taking advantage of that.
    u cant realy measure and get it down to a science for most shots, but
    1:1.618 is roughly a third and thats close enuff to have a strong effect
    on a photograph.
    also once you frame the shot with the rule of 3rds your going to intuitively
    make slight adjustments based on how it looks to you.
    and odds are that the better it looks to you, the closer it is to conforming with
    'the golden measure'.
    if your realy want to get a good understanding of this the thing to google is 'sacred geometry'.
    anyways, as stated above it only works on some scenes
    wile others simply dont lend themselves to it at all.
  10. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    The rule of thirds is an easy exercise/concept to get beginning photographers to stop composing everything in the center. Visualize a tic-tac-toe pattern evenly spaced over the scene, and compose so that one or more important subject elements are where the tic-tac-toe lines are. Where the lines cross is supposed to be even better.
    You can buy focusing screens for your viewfinder that have these lines. Also notice that software such as Lightroom superimposes them when you go to crop.
    Don't get caught up in rules of composition though. The rule of thirds and the golden mean are interesting to contemplate, and a helpful exercise when beginning, but they should give way to more intuitive composing. Rules of composition are a lot like astrology IMO. In some instances they work amazingly well, but there are plenty of examples of successful work that completely ignores them. Recent computer analysis of thousands of famous paintings show that the golden ratio/mean/rectangle is no more common than many other arbitrary number patterns.
  11. McKaso
    McKaso TPF Noob!
    Nov 22, 2008
    24
    Nebraska Panhandle
    Like many have already mentioned, it is a "rule" and sometimes rules are meant to be broken. When to break the "rules" comes with time and practice. The rule of thirds is not the only thing to think about when composing a photograph. A good article I refer to can be found at http://www.picturecorrect.com/photographytips/composition.htm
    A Google search will bring up many other articles on composing a photograph.
  12. Synnove
    Synnove TPF Noob!
    Nov 3, 2008
    174
    Columbia, SC
    [​IMG]
    It's like this, right?
rule of thirds astrology
