Think I need polarizer
Discussion in 'Just For Fun!' started by Jeff Canes, Aug 31, 2003.
I need polarizer
  1. yes
    100.0%
  2. no
    0 vote(s)
    0.0%
  1. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,190
    22
    Hollywood, FLA USA
    My intend was a shot of the alligators.
    What I got was reflections of the trees in pond.
    [​IMG]
  2. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    The first filter purchase anyone should make is a polarizer. There is nothing wrong with the reflections, but in this case the gator is the subject and not the reflections.
  3. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    Yep, you need a polarizer. Now for the unsolicited advice (you knew it was coming...):
    Figure out what the filter diameter of the largest lens you may ever use on your camera is and buy a polarizer at least that big. Use step-up rings to use it on smaller diameter lenses. that way you only have to buy one (they are rather expensive) polarizer.
    For example, I have a Nikon Coolpix 4500 that uses 28mm filters. I have enough step-up rings that I can use my 72mm polarizer on it, as well as using it on all my 35mm lenses (except the new 28-85 zoom, which takes 82mm filters- oops!).
    Much more cost effective than buying several of each filter you use. :wink:
    Jim
