Well the most important question is what your budget is.
The moon has an angular diameter of only 1/2º from edge to edge. A 400mm lens isn't very much for that -- offering an angular dimension of 2.1º x 4.2º if used with an APS-C crop-frame camera body.
I use an apochromatic telescope (in my case it's a TeleVue NP101is -- it has a 540mm focal length at f/5.4. -- it's a 101mm aperture.) But I use a TeleVue 2x PowerMate (basically a high end tele-extender). That takes it up to the equivalent of a 1080mm at f/11 -- which works well for the moon.
I'm not home so I can't upload a photo from the TV NP101, but here's a very similar image taken with a Meade 80mm apochromatic 3 element scope (this scope is 480mm f/6 and with the 2x PowerMate it's 960mm f/12).
This image was cropped slightly (but not much).
Gibbous Moon Flickr - Photo Sharing
Apochromatic refracters are considerably more expensive than achromatic (traditional) refractors, but there's a HUGE upgrade in image quality. Achromatic scopes only have 2 elements and suffer from chromatic abberation (dispersion) which is rather noticeable near the edges of the frame.
To be fair, it's not just a scope... you'd also need a mount (these scopes do not include a mount), and a 2x Powermate, a camera adapter for the powermate, and a T-ring.
EDIT: I missed the "I'm not looking to fill the frame" comment. In which case... something around 500-600mm might work for you.
Tim,
I had a question, will a 8 to 12 inch dobsonian telescope (lower cost for me) with correct eye piece and camera mount works too? Last year, I read about taking photos of the moon and planet and did not found and good answer.
Tim thats a great explaination of the difficulties of using a SLR on a reflector.
One minor correction, the focusing problems relate to Newtonian telescopes.
Dobsonian is the term specific for Newtonian scopes that are mounted on a basic alt-azimuth mount. The issue is just the same for equitorial mounted Newtonians (such as mine which can't reach prime focus with a DSLR, but can with Micro 4/3).
Another couple of other solutions similar to negative projection (your #3) are to use eyepiece projection either with both the eyepiece & a camera lens (called Afocal projection) or without the camera lens just the eyepiece (called positive projection). All the projection techniques change the focal ratio & magnification of the scope which depending on the subject can be good or bad.
Prime focus (no eyepiece or lens) in my experience gives much more contrasty images, but this may just be down to my eyepieces/technique.
I took this with my iPhone in 2013 (so this would have been with an iPhone 4) through my TeleVue NP101 via afocal projection. This is the Sun's photosphere using something called a "Herschel Wedge" (in my case it's a Lunt solar wedge) to filter the light to a safe level.
[/QUOTE]Tim thats a great explaination of the difficulties of using a SLR on a reflector.
OK, that's a nice sun pic but not sure how this applies to the moon pic question since the OP apparently does not have a "TeleVue NP101"
