this polarizer OK? slim on kit lens
Discussion in 'Photography Beginners' Forum' started by NikonNewb, Sep 4, 2009.
  1. NikonNewb
    NikonNewb TPF Noob!
    Jul 2, 2009
    14
    USA
    is this polarizer ok to use on a kit lens (18-55mm)?
    B + W 52mm Circular Polarizer Wide Angle Slim Mount Coated Glass Filter
    Thin construction with ultra thin optical glass. Used to prevent vignetting with today's larger wide angle lenses.
  2. shortpballer
    shortpballer TPF Noob!
    Aug 1, 2009
    664
    12
    San Diego
    I wouldn't recommend using a thin polarizer unless you are using an ultra wide angle lens. Since you are on crop frame the kit lens isn't ultra wide. So you can use a regular polarizer which is cheaper than the thin ones. The other bad party about the thin ones is that you cannot put a lens cap on them... the regular ones you can. Hope this helps
  3. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    On the other hand, his kit lens is a crop-lens.
    However, I agree with your other points.
  4. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Another vote for a standard CPL. Unless you've got a UWA lens (10-12mm) don't bother with a thin one.
    Good choice with the B+W, just make sure it's a multi-coated.
  5. NikonNewb
    NikonNewb TPF Noob!
    Jul 2, 2009
    14
    USA
    actually i wanted to go with the Hoya HMC, it's the same price.
    then there is the standard Hoya i could pick up for $20, but it's not multi coated, so.....
  6. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    Hoya is another respected brand. In either case, do get the multicoated version. It does make a difference.
