Three Basic Questions (Exposure / Auto Mode / Color Balance)
Discussion in 'Photography Beginners' Forum' started by laobrio, Aug 22, 2009.
  1. laobrio
    laobrio TPF Noob!
    Aug 18, 2009
    Hi Everyone,
    I have three basic questions regarding exposure and color balance, and would really appreciate your input and help. I will try to explain the problem(s) as well as I can with examples. The camera used is a Canon 5D Mark II, with the 24-105mm USM IS kitlens.
    1. The first question regards a problem I have in setting exposure so as to accurately capture scenes with a lot of contrast between bright and dark areas. I cannot figure out how to capture such settings so that both bright and dark areas are depicted with details and without clipping in a lifelike way. What always happens is that either the dark areas are lifelike and the bright areas much too bright (i.e. clipping, e.g. the sky is white instead of blue), or the other way around with the dark areas becoming so dark that all details are lost.
    For instance, the following is a picture taken out of a window of an abandoned building with shutter speed 1/640, ISO100, and Aperture F4.0:
    [​IMG]
    As you can see, the window and wall that frame the picture are very dark, one cannot make out details anymore. In reality the wall/window looked something like this (1/125, F4.0, ISO1000):
    [​IMG]
    Is there a way to capture both the scenerie AND the wall/frame accurately, that is, to make the city-scenerie look like in the first picture, but still have the wall/window look like in the second? What is the reason that I always get clipping/loss of details either in the dark or bright areas?
    2. The second question concerns the automatic mode of the 5D Mark II. While I almost never use it, I recently tried it out when I attempted to solve the above problem in order to see what settings the auto-mode would use. Photographing my dog in the shaddow of a car, sun in my back, I got the following rather terrible result:
    [​IMG]
    Why is the automatic mode so terrible with the white clipping in the background (sky was deep blue)? Is that normal? I could swear that a cheap pocket camera would probably have done a better job than this USD3000 monster of a DSLR.
    3. Finally, taking pictures at night, I can vary exposure settings and the pre-sets for white balance and picture styes as much as I like, I usually get a picture with a much too reddish tone. Below is an example. This is the least reddish/saturated I could manage to produce, but it still looked much blander and more neutral in reality. Shutter 1/10, F4.0, ISO4000:
    [​IMG]
    Would I have to simply adjust that in post? Or design my own picture style? How can I get rid of that reddishness/yellowishness/saturated look and obtain a neutral, bland looking picture of a street/building at night?
    Thanks a lot for your time,
    Best,
    lb
  2. laobrio
    laobrio TPF Noob!
    Aug 18, 2009
    Anyone? Even small hints as to my mistakes would be greatly appreciated. Thanks, and sorry for bumping so shamelessly.
  3. robertwsimpson
    robertwsimpson No longer a newbie, moving up!
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    1 - HDR
    2 - I don't know
    3 - post processing or manually white balance the camera.
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    1 and 2 are related to the dynamic range of the digital camera. (or film).
    Read here
    Dynamic range - Wikipedia, the free encyclopedia
    Because of the narrower dynamic range of the camera/film, we cannot capture what we see with our eyes as shown in your examples (photo 1 and 2.)
    In order to solve the issue, some may take multiple shots of the same scene with multiple exposures (Bracketing) to cover more range and then use software to combine them (Tone mapping). And a lot of people out there called it HDR (High Dynamic Range) photos.
    The other way to do it is use a flash to add more light to the dark area. So you use the camera and meter the bright area and then use flash(s) to light up the dark area. i.e. Fill flash, which fill in the dark shadow.
    As for the last one, it looks underexpose and the white balance is off. If you shoot raw, you can choose the right white balance afterward, or if you shoot jpeg, you can try to adjust it in the software.
  5. laobrio
    laobrio TPF Noob!
    Aug 18, 2009
    thanks
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    #1: HDR techniques. Not the garrish overblow so called HDR images often posted on this sit, but carefully tonemapped shots that look normal. There are some good discussions and tutorials on this site:
    Outback Photo
    #2: Can't help with the Canon, though a lot of whats causing the problem in you sample site can't be handled in a single shot, see #1.
    #3: Shoot RAW and adjust WB during conversion. Few cameras, if any, have a wide an adjustment range as do the better RAW converters.
