TIFF and PNG vs JPG, and one other question
Discussion in 'Photography Beginners' Forum' started by Mindy, Apr 3, 2009.
  1. Mindy
    Mindy TPF Noob!
    Mar 31, 2009
    106
    I'm using Elements 7 so the picture quality seems better; not sure if it's the software or not.
    1. Does it buy me anything switching from jpg to tiff or png after coming off the camera formatted jpg? I know all are 8 bit so I don't know if any corrections are being made to a tiff or png during post processing. There does seem to be more pixels/in, that's all I see that is better.
    2. What does C&C mean here? I've googled it and it means many things. I think it has something with requesting a critique.
    Thanks. :)
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    If you save as TIFF or PNG you won't lose any quality in the image when you save it repeatedly or make changes to it. TIFF (assuming you're using non-compression or lossless compression) and PNG save as full quality, whereas JPEG (even in max quality) loses some integrity every time you save it.
    I'm not sure if that made ANY sense. I'm tired.
    Here...
    JPG as TIFF and PNG good.
    RAW to TIFF and PNG better.
    JPEG to JPEG less good.
    There.
    lol
  3. Mindy
    Mindy TPF Noob!
    Mar 31, 2009
    106
    Okay, let me make sure I understand. If my camera is set to use the jpg format and I upload my images to my computer as jpg, then copying them as tiff or png is good. Why? Because the pixels/in goes up? and jpg is compressed and tiff/png is not? Are there any changes to a jpg file renamed as a tiff/png file after post processing?
    Thank you! :blushing:
  4. manaheim
    Sep 2, 2005
    14,394
    3,262
    Lemme try again.
    JPEG is a lossy compression format, which means every single time your picture is saved (including the time you camera captures it), a certain amount of information is thrown out.
    PNG and TIFF are lossLESS compression formats.
    So, when you take the picture as JPEG, you have lost some, but if you then immediately save it as TIFF or PNG, then from that moment on you will not lose any more data when saving the image.
    Whereas if you leave it as a JPEG, every time you save it you lose more information on the image, and thus, quality.
  5. Mindy
    Mindy TPF Noob!
    Mar 31, 2009
    106
    Okay I've got it this time, Chris. Thank you. :)
  6. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    Your camera saving as jpegs has already applied some processing and has already lost some information. Saving in jpegs, it's completely unavoidable.
    If the first thing you do is open the jpeg up and save it off as a tiff then use the tiff for further editing, you'll not lose any more image data from that point forward.
    In an image workflow, you want to move from lossless to lossy. For example, my workflow in terms of saved images is this:
    Raw (from camera) -> .psd files (layered, multiple edits, these may contain more information than the raw files) -> tiff (for print, sized to match my print house's printer specifications) -> jpeg (which I'll sometimes go directly from the psd file rather than th tif)
    Raw has the raw camera data
    PSD has all of my edits. I edit in 16-bit so it will retain most if not all pixel data that the raw file does plus all of my layered edits.
    Tiff flattens the PSD file into a single output file and applies non-lossy (data-only) compression. This doesn't affect image quality.
    Jpeg is my web-ready.
  7. Mindy
    Mindy TPF Noob!
    Mar 31, 2009
    106
    Thanks rufus5150! You are an invaluable resource!
  8. boogschd
    boogschd TPF Noob!
    Mar 19, 2009
    606
    ph
    comments and criticisms
  9. vlasta
    vlasta TPF Noob!
    Feb 20, 2009
    Things are not that grim with JPEG, because:
    1) The image produced by CCDs in cameras is not ideal. There is noise and colors are interpolated => in most cases the loss introduced by JPEG compression is unnoticeable or even not-existent (for example in bad lighting conditions when noise level is significant).
    2) You can avoid the re-saving loss by using the right software. It beats the JPG->loosless format->JPG way, because there are still 2 JPG compressions on the way.
facebook jpeg vs tiff
facebook tif vs png
jpeg vs tiff facebook
jpg vs png facebook
png vs jpg for facebook
png vs jpg vs tiff
png vs raw
png vs tiff
png vs tiff vs jpeg
tiff vs png
