Tilt & Shift effect in Photoshop
Discussion in 'Graphics Programs and Photo Gallery' started by colintinto, Jun 15, 2005.
  1. colintinto
    colintinto TPF Noob!
    Jun 9, 2005
    54
    Hi all,
    Does anyone have any guides to creating a Tilt & Shift effect in Photoshop? I got as far as finding out about Transform->Perspective, but I've got no idea what to do with it from then on. Anything I try just looks odd.
    Colin
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
  3. colintinto
    Jun 9, 2005
    54
    Hmm, will have a look at that.
    What I was trying to achieve is to fix the perspective. I had taken some pictures of buildings, but since I don't have a Tilt & Shift lens, and I was quite close to the buildings, the perspective is all wrong, and it looks like they are falling over backwards.
    After posting I played around a bit more and did manage to get it to sort of look OK. Just wondering if there was a better way.
    Colin
  4. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    try this:
    select all (ctrl+a)
    edit>transform>distort
    or
    edit>transform>perspective
  5. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    I think a tilt & shift lens does about the same thing as the perspective transform in photoshop. To use it, just grab on one of the corners and drag it around until you figure out how to get the result you want. However, if you have other objects in the shot or if there are distinct features of the building that give away the fact that you were shooting from a low perspective (like objects that hang out from the building), then it probably will never look quite right when you adjust the perspective, since the objects will be showing that you shot from a low perspective while the non-converging lines in the shot will try to make it look like you were shooting from straight-on.
adjust tilt in photoshop
fix tilt in photoshop
how to tilt an image backwards in photoshop
how to tilt page in photoshop
photoshop tilt backwards
photoshop tilt shift plugin
tilt image backwards photoshop
tilt shift photoshop plugin
tilt shift plugin photoshop
