time-lapse camera settings
Discussion in 'Beyond the Basics' started by Jigglitt, Mar 25, 2009.
  1. Jigglitt
    Jigglitt TPF Noob!
    Mar 25, 2009
    I've done a few day time time-lapse videos, but I wanted to try a day into night video. I know that almost everything must be set to manual, but does anyone know the proper settings so that when the day transitions from bright to dark, the images don't become underexposed for the night shots? I was thinking along the lines of aperture priority with everything else in manual so that the shutter speed is the only thing that would change, allowing for slower shutter speeds.... but again, I'm really not sure.
    Thanks for the help.
  2. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    I shot a day into night time lapse for one of our energy clients a few months ago. In this instance, the camera was facing west, directly into the setting sun. I wanted the shot to go from full day light to full nighttime with the lights of the city in the shot.
    I set the camera to shoot one frame every 8 seconds (iirc). I always shoot everything on manual. Our camera, a Sony XDHD camera, has built in neutral density filters so I dialed in a four stop ND filter, set the aperture to the correct exposure (probably f/11 but I didn't take notes so I'm just guessing) and waited. The shutter speed was set to normal (about 1/30 sec and never adjusted)
    As the sun dipped lower, naturally the ambient light grew dimmer so I would manually open the aperture just a fraction. I used the 70% indicator in the viewfinder as an exposure indicator so whenever the "zebras" in the viewfinder started to dip, I would open up the iris to keep the zebras in the viewfinder approximately the same. (to those who have no clue what "zebras" are, it's a series of alternating lines in the viewfinder of a video camera that indicate skin tone, or 70% of white level-kind of like the histogram on a still camera)
    Once the sun dipped low, I had to dial out the ND filter. I would do this quickly and reset my aperture to compensate for the sudden increase in light. During editing, we would edit out the few overexposed frames. Once the sun was completely over the horizon, I had to start dialing in some gain. Basically this is the reverse procedure as I did for the ND filters. I'd add gain, then stop down the aperture to compensate to keep the exposure constant.
    At the end of the shoot, I had gone from 4 stop ND filter with my aperture set around f/11 to +20db gain and my aperture wide open, all done manually in 1/8 stop increments.
    It made for a beautiful sequence.
  3. chadsdphoto
    chadsdphoto TPF Noob!
    Jan 23, 2009
    123
    Pierre, South Dakota
    I'm going to have to try some of this, thanks for the description of the process. Sounds very cool.
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I got a very successful timelapse just setting aperture priority and letting it go. The only thing special I did was set my meter to centre weighted average with the largest average setting since the sun moved across the frame and would have caused problems for complicated metering methods.
    I don't think manual would be the best way. Especially given the HUGE timelapses done in documentaries like "Planet Earth" which span for days at a time. I highly doubt someone was sitting there for a few days straight keeping the exposure right so something automated must be happening.
