Tips for Shooting Black Model
Discussion in 'Beyond the Basics' started by gabelimom, Dec 11, 2008.
  1. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    Hi Everyone-
    I'm going to do a beauty test shoot with a black female model next week. I'm shooting with Hensel strobes and a Nikon D70. The last time I shot a black model, her skin tone was waaayyyy off. It was quite yellow, and the makeup on her skin photographed very powdery. I found that to get the skin properly lit, I had to move the light closer, which then resulted in yellow skin. My camera was on manual and WB was on flash.
    Are there any tips that anyone can suggest to get the skin tones right? Do I need a gel to put over my soft box? Any help would be most appreciated.
    Thanks!
  2. viridari
    viridari TPF Noob!
    Dec 4, 2008
    86
    Raleigh
    [​IMG]
    I had umbrellas off to either side of her, and a bare strobe behind her hanging from a pipe on the ceiling. I metered off of the darker areas that still had detail like her hair and cleavage areas. I still don't think this is perfect... it's hard to do in a way that you don't blow out highlights like I did here. But I think even with the blown highlights it came out pleasing.
    I like how this came out better. Similar lighting configuration.
    [​IMG]
  3. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    My suggestion would be to set a custom WB. That's what I did in these shots.
    [​IMG]
    [​IMG]
  4. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    There is no real "trick" to photographing darker skin. I WB normally and set my exposure normally. The only thing I'll do differently is to add a bit more back or side light and overexpose it slightly.
    [​IMG]
    [​IMG]
    [​IMG]
  5. Mike_E
    Jan 26, 2007
    5,327
    266
    Optimal exposure is static no matter the color the person. (not be mistaken with preferred as in artistic)
    The best way to light a darker individual is with more specular (harder) light to show the high points as opposed to softer light to better bring out the shadows of a lighter skinned person. In either case it's the contrast between shadow and light that relays the information.
    A light to either side is usually easiest. If you have a flash meter you really want to break it out. ;)
  6. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,068
    89
    Kankakee, IL
    Agreed. In the studio, I will drag the background light a bit further from the background to keep my usual ratio.
    -Pete
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Don't forget to shoot RAW so you can adjust WB after the shoot if needed.
  8. roadkill
    roadkill TPF Noob!
    Jan 26, 2008
    392
    Atlanta GA
    Yeah... I always use RAW and fix it in post if necessary
  9. SnakeVnzl
    SnakeVnzl TPF Noob!
    Aug 4, 2007
    13
    Venezuela
    you can adjust WB in jpeg too.
  10. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    Thanks, guys. I'm going to custom set the WB and try the lighting techniques.
    Another q: when lighting equally on both sides, is it best to use the same equipment on both sides (i.e., two soft boxes, or two umbrellas)? What happens if you mix it up and use a soft box for a main light and an umbrella as a fill?
    Thanks!
  11. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    I have never done it, but I would expect that because there is a different amount of diffusion, there one side would be stronger than the other. Just an educated guess though. Try it and find out, that's the fun in it!
  12. jcolman
    jcolman TPF Noob!
    Feb 15, 2008
    200
    8
    Raleigh NC
    No reason why you can't mix it up. This shot was done using a combination of large softbox, umbrella and bare flash.
    [​IMG]
    this was done with just the softbox and umbrella.
    [​IMG]
black model shoot technique
dark skin model for photoshoot
dark skin model photography settings
how to photograph black women
modeling tips for dark skinned women
tips for black models
tips for shooting black models
