Tips on Shooting Dance Shows?
Discussion in 'Photography Beginners' Forum' started by BoxPhotographer, Nov 19, 2009.
  1. BoxPhotographer
    BoxPhotographer TPF Noob!
    Jun 23, 2009
    101
    Ontario, Canada
    I'm using a Nikon D80. Would a diffuser and flash bracket be handy? What settings should I be using? I'm am obviously going to shoot in RAW. There's probably going to be lots of colorful lighting, but it is probably also going to be dark. Any tips?
  2. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    Fast Lens!!!!! This is crucial. If there is bad lighting+fast people=fast glass. That is really the only option. Try and just pick up a 50 1.8 if you can't afford anything else. Bring up the ISO also depending on the situation. You can always reduce the noise considerably but missing a shot you can't go back and get that. Is flash allowed? Do you have an external flash. How far away will you be? Good luck
    tj
  3. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    I'll be up very close. I'll also be able to move any where I want. Will a Nikkor 18-200mm f/3.5-5.6 lense work?
  4. Kylerood
    Kylerood TPF Noob!
    Nov 13, 2009
    24
    Sisters Oregon
    There is a really good chance that pictures taken with that lens will turn out blurry even with you iso pumped up to 1600. Go out and get a 50mm 1.8 for $100 it will do a lot more damage (in a good way) than the 18-200.
    *i own both we have mentioned and have tried the 18-200 at concerts.
