ksmattfish said:A gelatin silver print is a traditional BW print. The black in the image is actually silver. 99% of BW machine prints from labs these days use a minimal amount of silver, and mostly dyes to create create the image (like color prints). These are not gelatin silver prints.
Toning is the process of replacing the silver in the image with something else that is more colorful, or archival, or both. The most common toners are sepia (olive/brown) and selenium (no color change or sort of purple), but there is also iron toner (blue), copper toner (red), and a few others.
Selenium toner is commonly used because at low concentrations it doesn't really change the color of the image, although it can make the blacks deeper, and it increases the archival quality of the print (300+ years if stored correctly).
danalec99 said:So, what do we do if we want a gelatin silver print?
danalec99 said:hmm, so...
1. Is there a considerable quality difference between silver gelatin and normal dyes? I mean, is there a quality difference in the final print?
2. Which one lasts longer?
3. And how big the check should be?
ksmattfish said:RC is resin coated paper. Meaning it's plastic coated.
FB is fiber paper. Meaning it's made of plant fibers, like many high quality papers.
RC paper usually has additives in the emulsion that speed up processing. RC developing times are about 1 min, while FB dev time is usually 2 or 3 min. RC fixes quicker than FB.
The plastic coating keeps RC paper from sucking up fixer, so it washes quicker (5 to 10 min). FB soaks up fixer so it can take up to an hour to wash.
FB is considered more archival, and is sort of the "fine art" standard.
Both kinds of paper are available in different finishes. Because of the plastic coating glossy RC is very, very glossy. While glossy FB looks more like semi-matte/pearl RC because of the texture of the fibers.
danalec99 said:FB seems to be my kind of paper
