Too much white in the picture?
Discussion in 'The Black & White Gallery' started by wpgalex, Nov 9, 2008.
  1. wpgalex
    wpgalex TPF Noob!
    Nov 8, 2008
    44
    Winnipeg
    During the winter I find it a little tough to get shots without the sky being blown out, how can it be reduced?
    [​IMG]
  2. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Wave when you see me go by.....
    I'll start with my thought:
    Underexpose the shot, then use layers in PS with different opacity settings.
    Once it's blown out that area is not retrievable.
  3. wpgalex
    wpgalex TPF Noob!
    Nov 8, 2008
    44
    Winnipeg
    Use layers....good tip thanks PNA
  4. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Can we see it without that transparent border? It's kind of intrusive.
    I think the white in the sky is OK because there's enough detail in the trees, but the snow on the ground just looks blown out.
  5. danjchau
    danjchau TPF Noob!
    Feb 27, 2008
    160
  6. Kegger
    Kegger TPF Noob!
    Dec 30, 2007
    569
    The warm, sunny, very polite South
    HDR would definitely work, as would a grad ND filter, or a CPL.
  7. rubbertree
    rubbertree TPF Noob!
    Sep 7, 2007
    727
    Canada
    Where I live, nothing will help in the winter with the blown out skies. There literally is no color or definition to them most of the winter. Just bright greyish white.
  8. SympL
    SympL TPF Noob!
    Jul 15, 2008
    407
    Ontario, Canada
    I do a lot of shooting in the winter and simply meter off the sky. If you capture it in control, then the subject and other interests in the shot can be brought up(if necessary) in pp.
    You can also bracket & blend or HDR as mentioned.
  9. wpgalex
    wpgalex TPF Noob!
    Nov 8, 2008
    44
    Winnipeg
    Sorry but what is an ND filter or a CPL, I apologize for my lack of knowledge but maybe that is why I'm here :)
  10. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
  11. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    A Neutral Density (ND) filter reduces the amount of light allowed to reach the sensor which will allow longer shutter speeds. They come in a variety of densities, but a 3 stop is what I have and it seems to work okay. They are neutral in color (although dark grey to the eye) and do not affect the color of you shot. Ever noticed those water shots where it looks like cotton candy?
    A Circular Polarizer (CPL) will have the same affect as if you put on polarizing sunglasses. It will reduce glare and make colors pop. You can rotate it on your lens to get they desired effect your after (within limits). It will offer the maximum results when you are shooting 90° to the sun.
    You can find these filters ranging from $10 to a couple of hundred dollars. Remember you are placing this in front of your (potentially) expensive lens. Do not go on the cheap. A good starting price point for a CPL is probably around $50, depending on your filter size. Multi-coated glass is what you'll want to look for.
  12. wpgalex
    wpgalex TPF Noob!
    Nov 8, 2008
    44
    Winnipeg
    Do any of you have a side by side comparison shots of CPL or ND's to see if it is a big difference, just curious.
    Never mind I found a couple in the previous link given :)
face is too white in the picture
if there is too much white in photos
photgraphy too much white
photo prints too much white
photo too white
photos too white
picture that has to much white
picture too white
too much white in picture
what to do when too much white in photo
