Too much?
Discussion in 'Landscape & Cityscape' started by domromer, Aug 21, 2007.
  1. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    Lately I have been doing a lot of work in PS. I'm not sure if it looks good or very fake I'm also having trouble with unsharp mask. It seems my results always seem to look over sharpened or not sharp at all. I'm posting a before and after here. Would you guys let me know what you think was done right or what could have been done differently/better
    [​IMG]
    Shot at 2007-08-21
    [​IMG]
    [​IMG]
  2. flyingseale
    flyingseale TPF Noob!
    Jan 21, 2007
    271
    If the fist picture is the AFTER, then you've done a good job. The second image is certainly nothing special, but you've brought out the detail with more saturated colours, better contrast and sharper. The only bit that might be overdone is the clouds which are have slightly more blown highlights in the first image.
    Mike
  3. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    One of the buttons I've been getting into using in cs2 lately is the 'fade -edit-'
    I'll perform the edit, click ok, then 'edit' and 'fade'
    You've lost some parts but added much more and given it depth.
  4. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    The first one is the one that has been edited. I had trouble posting them. I haven't seen that fade edit command. I assume it only works with layers right?
  5. outlandishogle
    outlandishogle TPF Noob!
    Aug 18, 2007
    108
    chicago
    i would deffinilty say u did a good job
  6. abraxas
    Aug 15, 2006
    10,417
    9
    In cs2 it works after an edit. For instance, USM. After you click 'ok', click edit (between file and image) on the top bar, you'll see an option that says fade sharpen. Likewise for curves, saturation, whatnot and etc... Try it. It blew me away when I first saw it.
  7. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    By the time I learn half of whats on CS2, they will be releasing the beta of CS5!!:confused:
  8. chrisk121
    chrisk121 TPF Noob!
    Apr 15, 2007
    77
    Edmonton Alberta
    I think it's a little too sharp. What settings did you use on usm?
