total beginner - C&C
Discussion in 'Photography Beginners' Forum' started by barleymalt, Jul 6, 2010.
  1. barleymalt
    barleymalt TPF Noob!
    Jul 2, 2010
    142
    I just purchased my first camera (a D5000) a few days ago. All these are shot with the kit 18-55VR as I'm till waiting for my tamron 18-270 to arrive.
    Please let me know what you think!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. peterhanowell
    peterhanowell TPF Noob!
    Jun 4, 2010
    48
    Tallahassee, FL
    Some interesting shots here, good job. You might want to think about controlling tilt (horizon parallel with photo horizontal lines, unless you intentionally avoid it). A few of the shots are underexposed, sometimes due to a subject with back lighting. Some fill flash can be possible, etc.
    Peter
    Tallahassee Photographer
    Tallahassee Wedding Photographers
  3. barleymalt
    Jul 2, 2010
    142
    Thanks. I've been having a hard time shooting skies with a foreground motive. It seems either the motive is almost a silhuette or the sky starts blowing out and sometimes just ends up completely white.
    By the way, is it just me or are half my images unavailable all of a sudden. Anyone know why this keeps happening? Works fine right after I add the links and then they start dropping out one by one. I can view the photos on my flickr.
    Anyways, here's a link to my flickr to see them all Flickr: barleymalt's Photostream
  4. PJL
    PJL TPF Noob!
    Sep 12, 2009
    418
    18
    Upstate NY
    Hence fill-flash. Check your camera's manual to see if it talks about how the flash functions in certain settings. For example, with some cameras, in program (P) mode, the camera will automatically assume that the flash is the primary source of light and select its exposure settings accordingly, while in Av mode, it assumes that the subject is already lit and the flash is being used for fill. You could also set your flash compensation through your camera's menu system. This is also helpful for removing harsh shadows on a subject's face in bright lighting. Just remember that you're using digital, so it costs you exactly nothing to experiment with different combinations of settings; therefore, experiment as much as possible :)
    If you're getting scenarios where you're taking a landscape shot and the sky is coming out correctly exposed but your foreground is dark and underexposed, you can use a graduated neutral density filter to even it out.
    I can't see flickr accounts at work, so I can't comment on your photos specifically; those are just a few things to keep in mind.
  5. barleymalt
    Jul 2, 2010
    142
    Definitely gonna pick up one of those filters, sounds like exactly what I need.
    Think the links are sorted now..
