Totally lost over Wide Angle Lens
Discussion in 'Photography Equipment & Products' started by Mohai, Sep 3, 2009.
  1. Mohai
    Mohai TPF Noob!
    Apr 3, 2009
    25
    Hi i live in the UK, i've had my Canon 1000d XS something its called elsewhere and i have been content with the kit lens.
    I now have been taking a lot of landscape pictures and i would love to have a wide angle lens to create dramatic effects etc.
    I heard cheapy lens can act bad in low lighting and other makes can take you up into the thousands, basically i want some recommendations on some lenses which are not too expensive but not dirt cheap.
    Any other questions to help and il happily answer!
    Thanks
  2. JustAnEngineer
    JustAnEngineer TPF Noob!
    Apr 11, 2008
    609
    Heart of Dixie
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    If you talked about the Field of View, the ultra wide angle lenses shown above are your best bet (Sigma has a new 10-20mm lens which cost more as well)
    If you worry about your kit lens is not fast enough, sometimes a tripod may help especially for landscape type shots.
  4. Mohai
    Mohai TPF Noob!
    Apr 3, 2009
    25
    Hi thanks, my kit lens is fast enough, (its the one that doesn't come with the IS)
    I didn't have that much idea, so i take it i will have spend a minimum of around £300 to get big field of view?
  5. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    oh .. ok . You must have the older version of the kit lens.
    The cost of those ultra wide lenses for APS-C cameras usually around that range. And I do not see anyone will drop the price anytime soon. In fact, they usually go up. Although it is hard to come by, but do check and see if you can locate a used one if cost is a concern.
  6. Mohai
    Mohai TPF Noob!
    Apr 3, 2009
    25
    Actually its the newer one, they got rid of the IS because i think it was too close to the 450D.
    I can afford a £2000 easily so £300 is no problem, it's just i can't justify buying a £300 lens just yet for a hobby, i can wait it out and i'll see how the market goes :p
    I'l take a look at second hand on eBay, thats a good idea, i do have an OCD with scratched glass or something on lenses though :p
    So a wider lens is a number lower, such as a 10mm lens is wider than 26mm lens?
  7. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    If your kit lens is fast enough, you can get Tamron wide-angles for really cheap. Probably a good place to start.
  8. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    The Sigma 10-20mm is a hell of a lens and as wide as you're going to go without fisheye... but if you're looking for truly funky effects, fisheye is the way to go.
best ultra wide angle lens for milky way
