Travel Lenses
Discussion in 'Photography Beginners' Forum' started by ketan, Jul 1, 2009.
  1. ketan
    ketan TPF Noob!
    Jul 16, 2007
    256
    Hi,
    Shortly planning to travel to London with family. Will visit mostly monuments and other site seeing in the majestic city. Plan to carry 30D with my 28-70 Tameron F/2.8 , 70-200 F/4 Canon. Thinking of buying Sigma 10-20 F/4-5.6. Request views.
    Thanks:blushing:
  2. ketan
    ketan TPF Noob!
    Jul 16, 2007
    256
    My only worry in case of 10-20 type wide lenses is that at times the objects near the edges appear 'funny'...not sure how to explain, like made of card boards. So the wish to make a choice to stick to 28-70 or go for 10-20.
  3. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,154
    930
    Woodbridge, Ontario, Canada
    Due to the extreme wide angle of the lens at 10mm ... you will get field curvature occuring at the edges of the frame.
    A extreme wide angle is handy to have to capture some scenes ... try not to over use 10mm.
  4. ketan
    ketan TPF Noob!
    Jul 16, 2007
    256
    At times I feel handicapped at Temron's 28, any suggestion for going wider without getting into perspective distortion?
  5. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Just becuase you have a 10-22, doesnt mean you always have to shoot at 10. I love my Canon 10-22, as the distortion has it place in certain situations. If you keep your camera perpendicular to the subject, it won't distort as much. But the second you tilt your camera up or down (as in look up at buildings), then it will distort more.
    You can always look at the Canon 16-35 L lens...a bit expensive,but its a great piece of glass.
    Then you have lenses that fall in the range of 17-55 which might suit your needs.
  6. dxqcanada
    Dec 4, 2008
    6,154
    930
    15mm or 16mm ... I use a 16mm f/3.5 prime.
    On my Sony a100 thats equivalent to a 24mm Full-Frame.
  7. ketan
    ketan TPF Noob!
    Jul 16, 2007
    256
    May be then I will go for Sigma 10-22.
    Only disppointment is that to cover the range will need to carry three lenses.
    10-22, 28-75, 70-200.
  8. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I believe the Sigma is 10-20mm only. The 10-22mm is the Canon EF-S lens.
    And Sigma has a new 10-20mm version now which has a constant max. aperture. :)
  9. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    With your 30D, and only 28mm, you really don't have a wide angle lens,,, the short side at 28mm converts pretty close to the old 50mm for a film DSLR..
    But you also don't need to go ultra wide to the 10-22, because you will get distortion..
    Why not look into the 17-40L.... It''s a pretty good fit..
    You also don't really ever need to "cover" all your focal distances.. The difference between a 40 at the long end of a 17-40, and the 70 at the short end of a 70-200 is really pretty insignificant in practice
  10. Andrew Boyd
    Andrew Boyd TPF Noob!
    Jun 9, 2009
    81
    New Orleans, Louisiana
    The Canon 18-55 will do what you're looking for and is pretty cheap. Might want to consider it. For sightseeing you won't need the ultra, ultra-wide of the 10mm end of things....unless you're really just looking for a good excuse to get one!:mrgreen:
    Andrew
    TheDiscerningPhotograher.com
  11. ketan
    ketan TPF Noob!
    Jul 16, 2007
    256
    Thanks friends, I have one kit lens of 18-55, will stick to it and hope that it will serve for all my wide angle needs to shoot architecture.
  12. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    For what you are wanting I would say go with Tokina:
    Tokina | 11-16mm f/2.8 AT-X 116 Pro DX Autofocus | ATX116PRODXC
    This lens has had some great reviews. I want this lens myself for my D80.
    It is made for the smalled sensor on non full frame Dslr's and gives a true 11mm-16mm with the ability to shot at f/2.8. (no cropping effect)This lens is great. I tried one out at a local shop and liked it very much. I think you would be very happy with this lens for what you are looking for. When I can afford my next lens this is at the front of the line.
    Check it out as I think you will like it.
    Cheers.....
    Daniel
