Tried Reversing my lens today, see results
Discussion in 'Alternative Techniques & Photo Gallery' started by NYY, Dec 10, 2005.
  1. NYY
    NYY TPF Noob!
    Oct 23, 2004
    150
    New Jersey
    I had to do it handheld, so focusing was very difficult, but some turned out really well. I'll add more photos soon. These were done with a 300d and a reversed kit lens. I might try my sigma 70-300mm lens later.
    [​IMG]
    my giant pen
    [​IMG]
  2. PlasticSpanner
    PlasticSpanner TPF Noob!
    May 1, 2005
    4,125
    51
    Cheshire, England
    I've found my shorter, wider lenses make the higher magnifications.
    (Is this right/normal?)
  3. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    They will be better. Also, zooms are terrible for this kind of thing. Nose around eBay and see of you can pick up a cheap prime lens. It shouldn't cost much becasue you just need to make sure the filter is the correct size. :)
    So, having fun then, NYY? :mrgreen: :thumbsup:
  4. NYY
    NYY TPF Noob!
    Oct 23, 2004
    150
    New Jersey
    yeah i noticed the same
    im still trying to find out how this actually works
    posted at the same time :p
    yeah its pretty fun, but very akward
  5. crawdaddio
    crawdaddio TPF Noob!
    Dec 5, 2005
    1,157
    14
    Central IL
    What is a 'prime lens'?
    NYY----so you're just holding the lens? I'm gonna have to try this!:mrgreen:
    Thanks,
    ~DC
  6. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    A prime lens is designed for just one focal legnth e.g 28mm or 50mm as opposed to a zoom lens which has a range of focal legnths e.g 35-70mm
  7. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    NYY, are you mounting the kit lens directly to the camera? Or are you mounting it to another lens? Like a zoom lens attached to camera, and reversed lens on the end?
  8. NYY
    NYY TPF Noob!
    Oct 23, 2004
    150
    New Jersey
    all i did was hold the lens in one hand to (in reverse) to the body of the camera. then i moved in on my subject until it came into focus
  9. hobbes28
    hobbes28 Incredible Supporting Member
    Jul 10, 2004
    4,807
    41
    at work...
    Go ahead and get used to that hook in your mouth because it's one that won't go away for a long while. :D
  10. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    Is it possible to increase the DOF when reversing a lens or am I stuck with about 10mm? :lol:
  11. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    You're stuck with the 10mm. It takes a while to get used to but after you shoot a few, you learn tricks to get around it.
  12. alexecho
    alexecho TPF Noob!
    Jun 8, 2005
    200
    I'm confused. You take the lens of and physically hold it in front of the camera? That can't work, can it? Tell me I've mis-read what you're all talking about.
