Tripod For Nikon D70!
Discussion in 'Beyond the Basics' started by Wirral Bagpuss, Jun 5, 2005.
  1. Wirral Bagpuss
    Wirral Bagpuss TPF Noob!
    May 25, 2005
    53
    Liverpool, United Kingdom
    I am the proud owner of a Nikon D70. Can anyone recommend a good tripod to use with it? Am prepared to pay up to £40 max.
    Thanks ! :thumbup:
  2. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    • Like Like x 1
  3. Wirral Bagpuss
    May 25, 2005
    53
    Cheers for that !! I would hate to think i got myself a tripod and then see my Nikon D70 camera fall to the ground ! :cry: so i wanted to check this out before pressing ahead ! ;)
  4. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    If you knock it over, it will fall to the ground - gravity and all that ;)
    If you are worried about stability, it has a hook at the bottom of the centre pole, you can hang a bit of weight on this to increase stability - bag of shopping, small child etc.
  5. Wirral Bagpuss
    May 25, 2005
    53
    Hahahaaa! :biglaugh: :biglaugh: :biglaugh: :biglaugh: Nice one !! :hail:
  6. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    I use a very 1970's Velbon which doubles as a handy self-defence weapon. I find that the modern lightweight things are flimsy and prone to shaking in the wind. Also, you put anything over 400mm on the front and they keel over - bad.
    My beast is just like this chappie here:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3325&item=7520122001&rd=1
    "Sturdy" is an understatement - it's damn heavy, ultra-reliable and you don't need to faff about with weights. It won't move, even if you fall over drunk into it (I've tested this)
    Rob
  7. railman44
    railman44 TPF Noob!
    Aug 23, 2004
    580
    Lincoln, NE
    I bit the bullet and bought a used Gitzo (Reporter model) on eBay. Built like a tank and quite heavy. Attached a ball-head Gitzo (middle size) and I'm good to go. Nothing short of a tornado would blow that over. Many good names to choose from though such as SLIK, Manfrotto, etc. etc.
  8. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    yeah, i've never knocked a tripod over but i have had the plate come disconnected while in use. Luckily only damaged the lens. but it still sucked. this is best avoided by being careful
  9. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    A guy I agree with... I've only wasted 50 bucks.
    When you have a 1500 camera and a 1500 lens hanging off it, I prefer to support the thing properly.
    http://www.bythom.com/support.htm
    EDIT: Rob - How do you like hiking with that thing? ;)
  10. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    It's not as bad as my golf bag!
  11. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Generally look at the way you will use it. If you are shooting sunrises in the field; spend some money to get a deal that is light and super sturdy. You may be able to get away with a less expensive model with night shots and or still life's at home. Shooting a lot of commercial work requires the flexibility of a model with all the bells and whistles.
    A used tripod is not a bad idea. The commercial models are super strong and do not wear out. I would be a little leery of buying a model with out playing with it first. Ease of operation is important. Ease of minor level adjustments is also something to consider. Details like screwing the legs as opposed to a lever lock is important to you. After you buy the tripod I suggest the 23 dollar "sprit level" for your hotshoe. Or a 6 dollar torpedo level. The idea is that since you are taking the time to set up the tripod; why not level the camera? I have found that idea handy for wide shots and commercial work.
    Of course keeping one leg pointed at the subject and under the lens is a good idea.
n70 tripod
camera tripod nikon n70
sturdy tripod for nikon d70
