Tripod Mount Ring
Discussion in 'Photography Beginners' Forum' started by ryyback, Aug 17, 2007.
  1. ryyback
    ryyback TPF Noob!
    Jul 17, 2007
    176
    Do we really need to use a tripod mount ring with say a 70-200, or can I just hook up my Canon XTi and the 70-200 to the tripod?? The tripod holds 13 LBS or so-:)
    Thanks all.
    I just found this, so maybe this will help others?
    "I should mention here that the 70-200 F4 lenses do not really require the tripod ring for shooting from a tripod"
  2. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    I never handled a XTi or 70-200 f/4 but my instinct would be to try and attach the tripod as close as possible to the centre of gravity i.e. close to the heavier piece of equipment; in this case the lens (~700 g vs ~500 g for the body).
  3. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I believe the point of the tripod collars for lenses like that are to take the pressure off of the mounting ring of the camera. I have a Sigma 70-200 f/2.8 which is quite heavy. When I put it on a tripod, I use the tripod collar and mount it to the tripod there. It makes it much more stable and the weight of the lens is supported by the tripod.
  4. ryyback
    ryyback TPF Noob!
    Jul 17, 2007
    176
    Sounds like good sound advice-Thanks all-:hugs:
