Tripod upgrade...
Discussion in 'Photography Equipment & Products' started by Big, Jan 30, 2010.
  1. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    I am thinking about getting a new tripod. I don't use the one I have much but the lock for the vertical pivot is slipping and I don't like the idea of that with a $700 lens hanging off the front... I found a Manfrotto tripod I like but in the description above the picture it says that it holds 8.8 pounds and extends to 62 inches. Both of which I'm not crazy about. If you look at the specs it says max height 52.5 inches and a max load capacity of 11 pounds... I'd like to have something that extended to at least 62 inches seeing as I'm just over 6' tall. Also would like it to hold more than 8 pounds. Is there something I'm missing as to why these numbers are different on the same item? I love the design of the tripod and the way that it pivots to different angles for over head shooting. Does anyone have this tripod?
    Thanks guys!
    -Big
  2. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    I would e-mail Adorama. I would guess their title description is wrong, but you could probably do a simple search on B&H to see what their specs say and which it matches.
  3. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    That's a good idea. Thanks
  4. srinaldo86
    srinaldo86 TPF Noob!
    Jan 20, 2010
    321
    Okinawa Japan
    lol, i've never thought about the height of the tripod matching or compensating for my height.
    i think i've just accepted the fact that nothing normal is made for people like me. however thanks for posting that, it will take account in my tripod shopping trip tomorrow.
  5. bentcountershaft
    bentcountershaft Been spending a lot of time on here!
    Nov 1, 2009
    2,516
    1,026
    Southern Indiana, USA
    Be sure to update with what you find out as I'm considering purchasing this same model in a few weeks.
  6. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
  7. BAmereihn
    BAmereihn TPF Noob!
    Oct 27, 2009
    130
    one is prob giving specs on just the legs while the other is prob giving specs with head attached
  8. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    I thought of that too but wasn't sure since they are both kits.
  9. BAmereihn
    BAmereihn TPF Noob!
    Oct 27, 2009
    130
  10. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Oh ok, they must drop the load rating due to the head. Is 8.8 pounds still enough to hold a 300mm lens?
  11. uplander
    uplander TPF Noob!
    Mar 22, 2008
    536
    S.E. WI.
    You really want to double the capacity for the weight you plan for it to bear. If you have a camera, lens and head weight of say 8lbs than you want a tripod with a weight capacity of 16 lbs. the reason is you need to take in to account effects of wind and the need to hang a stabilizing weight on windy days. Your head should support 1.5x the weight of camera and lens.
    This is the generally excepted standard for tripods and heads.
    You want a saftey margin for unexpected things.
  12. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    I have the 190xprob and think it's an awesome tripod. Probably would have gotten the 055xprob if I could go back but i'm still more than happy with the 190. I don't have a big 300/400 prime so I can't comment on how it holds to that but I've had it with the body 70-200 flash and all that good stuff mounted without a problem. I have the 486rc2 head which is nice but the 488 is a nice head to because you get the ease of use of a ball head but can turn it side to side with a pan screw. It really is a great tripod and I wouldn't hesitate with it. GL
    TJ
tripod rated for 8.8 lbs with it hold d300 and 70-200
