Tripods: 3-way Pan head vs. Ball head
Discussion in 'Photographic Discussions' started by frXnz kafka, Nov 20, 2008.
  1. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    What's everyone's opinion on these two tripod heads? I've only ever used a pan head on a cheapo tripod, and it seems to me that the ball head would be more likely to slip with a heavy camera.
    So if you have experience with both, tell me the pros and cons of each.
  2. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
  3. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    I have one of each, I much prefer the ball head, it is far easier and quicker to set up.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    for most things i do... ball head.
  5. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Not really a fair comparison, but I really like my manfrotto ball head compared to the cheap pan head I have.
  6. frXnz kafka
    Jul 9, 2007
    517
    Maine
    Could you say why? I'm not terribly concerned with speed when I'm shooting on a tripod, so what other advantage is there to a ball head?
  7. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    One of the major advantages of using a ball head is the simple operation it provides. A single knob is faster and easier to operate than multiple handles and levers. While one hand takes care of the knob, the other can be on the camera and positioning it as you look through the viewfinder. When you find that spot you’re looking for, give it a twist and away you go.
    In addition to the simple activation of controls, the motion provided is equally elegant and simple — you might even say intuitive. A full range of rotation means there are no limits to which direction you can point the camera, and the motion feels quite natural and uninhibited. Your own hips and shoulders work on the same basis as the ball head: the ball and socket joint.
    But besides the ergonomics and ease of use of the ball head, they’re also generally more compact than a pan head. There are no adjustment arms that hang off the head, and the single socket can be designed to occupy much less space than three separate hinge joints.
    Plus they look cool.
    Now of course there are downsides to every good thing out there. In the case of the ball head, it’s mainly the price. For a ball head of equal quality and capability to a pan head, the ball head will almost always cost more money. The main reason they cost more is because that precision ball and socket joint is much more difficult and expensive to manufacture than three decent clutched hinges.
    The other downside of the ball head is with the strength and precision. Ball heads that are comparable in price to pan heads will typically support less weight (important for folks with big heavy lenses). The motion and the ability to stop the motion will also be of lower quality and capability than the pan head. It’s not to say that you can’t get a ball head to carry a heavy load with smooth operation — it’s just going to cost more.
  8. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Heads are like everything else they all have their place. You need to decide what fits your needs the best. Here are the three most common.
    Pan/Tilt heads: Easy to adjust in very small increments with out skewing the whole thing up. Excellent for panoramas, macro work, architectural, studio and precision work.
    Ball head: Quick to adjust. Takes more time and care to make minor adjustments. Compact for travel. Excellent general use head. Most adapted for field use, nature, landscape. More expensive ball head with an independent panning feature are good for panorama's as well.
    Grip style ball heads: Very quick to adjust and control. Excellent in the studio. A modified 322RC2 head is my preferred head in the studio for portrait work.
  9. slapshot™
    slapshot™ TPF Noob!
    Jul 12, 2008
    43
    Alberta
    Correct!
    Panhead = video
    Ballhead = still photography
  10. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I could!
    but it is all said by reg already :)
  11. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I use a pan head now, but by first high end head was a Manfrotto ball only model, quick found that I did not like it because you could not simple rotation on the center axis, some the top end models like the Gitzo 1377M or Manfrotto 468mgrc in $250ish range will rotation on the center axis, so you also get side to side pan
  12. table1349
    Sep 9, 2006
    Incorrect.
    Panhead = precision movement, more cumbersom to adjust.
    Ballhead = harder to move in small precise movements. Quick to adjust for general usage.
    Fluidhead = Video.
3 way head vs ball head
3 way panhead vs ball head
3-way pan head vs ball head tripod
3 way pan head vs ball head
ball and socket vs 3 way tripod
ball head tripod vs pan head
ball head vs pan head
ball heads vs panheads
tripod ball head vs pan head
