Trouble copying raw images
Discussion in 'Digital Discussion & Q&A' started by rob91, Feb 20, 2008.
  1. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    Here's the story. I have a laptop which I could copy my raw over to fine, straight from the cam (it's running Windows Vista). My desktop has XP Pro, and I tried and I tried but I could not get the raw to copy over. My jpegs went just fine, but no raw. I installed the camera raw, windows imaging component, and pretty much all the installs off of canon's website. I then used my card reader and I got it to work, although I couldn't do it the auto way through "Microsoft scanner and camera wizard" (which is what worked on the laptop) rather I had to manually open the files and copy them over.
    I know it's not a huge deal, but any suggestions on how to fix this would be great.
    Oh, and I have a rebel xt if it helps.
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I have always just manually copied the files over...never had a problem. Sorry, I don't know much about the wizard.
  3. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    Yeah, it would also be nice to copy them straight from the cam, I like to minimize how often I pull the card out of it.
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I don't pull them right off the camera (I never attach the camera to the computer)...I either use a card reader or the built-in card slot in my desktop.
    I put the card in and explore to it, then just drag and drop the files onto the hard drive.
  5. Bill Boehme
    Bill Boehme TPF Noob!
    Feb 17, 2008
    6
    Instead of using Microsoft utilities which may not work with some RAW files, use EOS Utility that came with your camera. It will start up automatically and then you can use it to download the files directly from your camera. I prefer it to removing the card and plugging it into a card reader because each time that the card is unplugged and then plugged in again is another opportunity for a damaged pin on the camera connector.
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I've seen and heard about too many people catching the cord and sending their camera smashing to the floor...I'd rather pull the card than connect it to the computer. That's just IMO.
  7. rawrasaur
    rawrasaur TPF Noob!
    Feb 24, 2008
    16
    the easiest way to do this is to attach your camera, then go to windows explorer, select the camera(which will be seen as a harddrive with the icon of a camera) and then right click on it, and hit explore. then just drag and drop what you want.
