Trouble with my SD card
Discussion in 'Photography Beginners' Forum' started by les_rokr, May 19, 2007.
  1. les_rokr
    les_rokr TPF Noob!
    May 18, 2007
    42
    Arizona
    Aside from being a complete noobie to photography, I'm having some technical issues as well.
    Today I slipped my SD card into the reader to erase some old photos, and I copied the pictures I liked to my computer.
    But when I highlighted all the files I wanted to delete, my computer says the disk is "write protected". I figured I must've accidently locked the card, so I took it out only to notice that it wasn't locked.
    I put it back in, and my computer still says the same thing.
    I right clicked on the drive the card was in to browse through properties to see if there was anything I accidently enabled. I found nothing.
    Now I can't erase anything off of my only SD card.
    Any help would be greatly appreciated,
    -Alex
  2. Stretch Armstrong
    Stretch Armstrong TPF Noob!
    Mar 31, 2007
    254
    Alabama
    If you have copied the shots you want to keep, try deleting or formating the card in the camera.
    If this doesn't work, there are free programs to rescue SD cards on the internet. Just google rescue SD card.
    Good luck.
  3. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    did you by chance protect the images in the camera? that may cause the issue youre having.
    also, right clicking the drive itself wont tell you if the images themselves are write protected. you have to click the pics themselves. then youll be able to see at the bottom of the properties page if they are write protected (read only) or not.
    if you have an SD card with a physical lock, make sure youre not inadvertantly activating it when you push the card in.
    if all that fails, you can try to reformat the card either in the camera, or in the drive.
    good luck, and let us know how you make out.
  4. les_rokr
    les_rokr TPF Noob!
    May 18, 2007
    42
    Arizona
    Ah, I had already tried reformatting the card in the drive, but not in camera. My computer wouldn't let me format it in the drive, but it worked just fine in the camera.
    Thanks!
  5. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    im glad you got it worked out. i know id be lost if i didnt have a way to save new shots on the only card i have for my camera.
