I doubt photoshop will achieve the affect you are looking for. The headshots you posted from other photographers are professionally lit, ...
...which means multiple off camera flashes, softboxes, umbrellas, and wireless triggers, not to mention a quality lens.
Do you think the d80 with a manual strobe and one to two umbrellas would be sufficient on a outdoor sunny day?
I think it matters most whose hands they're in, the prevailing situation, and the desired outcome. It's not about equipment. It's about how the equipment is used.
There are no shortcuts. Learning first, excellence later.
Better... or more.... or different equipment is not the first concern.
-Pete
...after I read up a ton more on photography, will I eventually be able to achieve the look I am going for?
Hi,
I have been thinking about this, and I really do like photography. I would like to be able to help my sister and take my own photos for future projects I will be working on. I know for my senior project I will want a good camera to take pictures with.
I looked up the Nikon D50 you listed but I don't see it for that price.
Nikon D50 - Google Product Search
Google has it for $589 and $831. It also has less MP than my current point and shoot. Is that the best camera you can recommend for me and what I am trying to accomplish?
Thanks. =)
Besides the body, I would just need a 50mm F1.8 and a manual strobe? To take really well portraits? Would I need an umbrella if I am shooting outside? I would just carry it and set it up in a good spot to bounce the light onto my model, correct?
Most of those "cheaper" sites are bait and switch scams. Stick to trusted sites like BH, Cameta, Adorama, Ebay, etc.Edit: wouldn't it make sense to buy it from one of those sites for cheaper and then get the 50mm F1.8 lens for it? The one on ebay has a different lens I might not need.
Well... not necessarily. But if you want to create proper lighting as opposed to learning to recognise proper existing light (which requires some training), then yes... you'll need to acquire and learn to use lighting equipment.
-Pete
I had some more practice today..
I'm curious about what you are learning and how you've applied it all. Would you take any one of these photographs and critique yourself? Tell me why you've make as you did and what you feel you lack.
Thanks.
-Pete
I will try vertical pictures on Saturday.
Would someone be so kind to guide me through creating a depth of field? I tried the virtual camera site that was posted above and that made sense. I was able to focus on those examples. But I can not figure it out on my camera...
I want my model to be in focus while the background is not.
On the screen I have a number that goes from 2000 to 30"..
Then there is the number F3.5 to 8 when zoomed out and when zoomed far in it goes to F10.
Also in my settings I can set the ISO to auto or 100 to 3200.
The focus can be changed from multi AF, Center AF, Spot AF and 0.5 to 7.0 and also unlimited.
I tried reading the manual but it doesn't explain it well. I would assume F3.5 would give me a good depth of field? And then I play around with the other number (2000 to 30") till I get a good contrast, but what about the ISO and focus?
I am confused because it seems I will have to manual go into the settings every time I want to take a different picture to adjust the focus and ISO...those are not done on screen easily like the shutter and apature are.
Thanks .
I noticed from when I first started I was unaware of where the light was coming from. ...Overall I think my latest pictures look more professional, ...
