trying to understand hyperfocal distance
Discussion in 'Beyond the Basics' started by EandSphotography, Mar 15, 2010.
  1. EandSphotography
    EandSphotography TPF Noob!
    Nov 30, 2009
    32
    Knoxville tennessee
    Hi everyone. I'm trying to understand hyperfocal distance and how to use it correctly. I'm most interested in landscape photography and from what i've read this is the best way to get those classic front to back sharp pics that you see in magazines. So this is where i need your help. I havent been outside to actually use what i've think i've learned yet, but wanted to get a headstart on your advice and when i come back in , i'll update what i've come up with. So, i'm shooting a canon 50d and we'll use a 16-35mm 2.8 lens. set at 35mm for this experiment. I'm using a website and iphone app called DOFMASTER.com if you want to follow along.
    So choosing my camera from the drop down list (50d) so that it properly calculates the crop factor into the equation i put in the focal length of 35mm. next selection is f-stop. we'll choose f-16. and then finally subject distance will be 5 feet. So what i'm wanting to do here is take a picture of a small tree that will be in focus but also have the background which goes basically out to infinity and have it in focus ( or as much as possible)
    So with those selections the dof calculator comes up with this...
    Subject distance=5 feet
    near limit 3.65 feet
    far limit 7.93 feet
    total 4.28 feet (i assume this is the total depth of field at this aperture)
    In front of subject = 1.35 feet (32%)
    behind subject = 2.93 feet (68%)
    Hyperfocal distance 13.3 feet
    circle of confusion =0.019mm
    now, if your on that website there is a diagram showing a picture of a man shooting some trees. it says :
    focus at the subject distance of 5 feet and the near limit of acceptable sharpness is 3.65 feet , the total depth of field is 4.28 feet and the far limit of acceptable sharpness is 7.93 feet.
    second diagram shows the same image but it is focused at the hyperfocal distance of 13.3 feet and the depth of field extends from 6.65 feet to infinity.
    This is where i'm getting confused a bit. So do i now focus at 13.3 feet past the subject that i was originally shooting at 5 feet or do i focus 13.3 feet from where i'm standing which i guess would be about 8.3 feet past the original subject??
    next question is according to this diagram if i focus at the hyperfocal distance of 13.3 feet my depth of field will extend from 6.65 ft to infinity.
    But originally i'm 5 feet away from the little tree. So does that mean i have to move back 1.65 feet to get the tree within the depth of field??
    I hope i made this somewhat clear as to what i'm asking, but if you have time and go to that website it will be easier to see what i'm talking about. on the page it is the tab on the left that says on-line DOF calculator. There is also an iphone app that i downloaded this morning for $2 which does the same thing that i'm hoping will come in handy for use out in the field.
    I know this is kinda long so i appreciate you guys taking the time to look over it and help me out.
    Thanks,
    Erik
  2. EandSphotography
    Nov 30, 2009
    32
    Knoxville tennessee
    ok, so i see a few people looked at this post, but no replys yet. That's ok. I was outside playing around and this is what i've come up with so far. I changed my measurements just a bit so that when i focused on the hyperfocal distance the subject (the small tree) would fall into the near part of the DOF range.
    So , i did a shot a 35mm focal range at f-18. the tree is at 9 feet. The near dof is 5.13 feet and the far is 36.6 feet . total dof = 31.5ft DOF. The hyperfocal distance on the calculator showed 11.9 feet.
    2nd shot still in same position of 9 feet away from the small tree but this time i focused on an object that i placed at 11.9 feet away. near DOF shows 5.95 feet and far DOF shows infinite on the calculator. While i can say i do see a difference between the two as far as the DOF goes, i dont believe it's "tack' sharp like it should be using this method.
    Also, i should mention in case your wondering, the distances are exact cause i set it up in my backyard and used a tapemeasure to be sure i had the exact distances.
    So, what's up? how can i get that tack sharp magazine picture that you see everything sharp front to back??
    help help help.
    Erik
  3. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    Well that is a lot of info. I really haven't studied hyperfocal but according to "Understanding Exposure" and what you probally already know the smaller the F-stop the more DOF throughout the picture. I think the problem is going smaller the f22 you lose a lot of quality. Now I really enjoy landscapes and usually stay around F8 to F16 but My subjects are further than 5 feet. So sorry for not really answering your question and Im sure someone will eventually chime in with a great answer.
  4. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    Maybe the answer is stacking the photos using the sharpest f-stop.
  5. EandSphotography
    Nov 30, 2009
    32
    Knoxville tennessee
    Hi there Rock. thanks for chiming in. And yes, while i understand that the smaller f-stop will give you greater DOF, i've also read that it will cause diffraction and cause the image to appear softer in the background. So, at f8-16 , i would agree would give you the sharpest image, but i'm just not seeing it. before i just used to think it was because of the lens i was using ( a cheap tamron zoom) but now i've got a $1200 l series lens stuck on the front so i know that I'm the problem and not the lens. Now we just have to get that part corrected and i'll be good to go.
    Hope i get some good answers. And yeah, i know that it was a lot of info in that first post but i wanted to be thorough.
  6. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    I really think your answer is photo stacking. Use the sharpest f-stop and place the camera on a tripod. Take numerous pictures without moving the camera and exposure but change the focus every time manually . Then in photoshop combine all the photos to get a picture thay is tack sharp throughout. If its not the answer it sounds like fun anyway. Good luck!
  7. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    Oh do you have an example picture in mind?
  8. Overread
    May 1, 2008
    24,001
    4,152
    UK - England
    I've never done hyperfocal focusing, but I always thought it was refering to the markers on the lens for distance rather than actual distance in the real world - though I could be totally and utterly wrong on this.
    Focus stacking is an option, but its more limited in landscape since you have to remember that each shot will take time to expose and even light wind will lead to leaves and other frame content moving. If its like HDR blending a black land to a bright sky a little bit of movement is no worry as the two areas don't affect each other - but it would be a nightmare if you were shooting a woodland scene since each time you try to link the trees together you would have blur from the leaves being in different positions.
    Like I say its not an area I know well (landscape) and whilst stacking is an option I'm sure the hyperfocal focusing can work. You might want to creep down and try f13 or f10 just as f16 is right on the line where diffraction tends to start to cause the most trouble (it varies from lens to lens and camera body to camera body)
  9. KmH
    Apr 9, 2009
    40,526
    5,539
    Iowa
    You need to focus on something at 13.3 feet to have the front of the DOF be at 6.65 ft.
    If you move the camera all the numbers change. All measurements are made to the image sensor plane, not the front of the lens. Your camera should have an icon on it showing the image sensor plane.
  10. Mike_E
    Jan 26, 2007
    5,327
    266
  11. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    When i shoot landscape, i mostly use an aperture or F8 to F16 and focus on the one third of the image.
    if the sky is taking 1/3 and the foreground 2/3 i try to focus on the horizon, then i use an F stop that will make my foreground look as sharp as possible
    lets say your using a wide angle lens at 13mm and F11, any thing farther than 2.43 ft will be sharp, even some object close to in you placed in the foreground. This is why i like to use wide angle lens for landscape, once your using a slower fstop, the distance where object become sharper go shorter and shorter!
    all depends on the focal lenght you are using and the F stop and where do you focus.
    if you take the shot and the the main subjet of the photo is rock in the foreground, have the forground take 2/3 of your picture and focus on the rock. if you did set your F stop correcly, the background should be relativly sharp/in focus
  12. matfoster
    matfoster TPF Noob!
    Feb 12, 2010
    722
    Nuneaton, Warwickshire, UK
    ascertaining accurate distances like 6.25 feet in a real world situation (?) ..easier just to bracket a few shots (aperture priority) F8, F11, F16.
understanding hyperfocal distance canon
