Two filters stuck together.
Discussion in 'Beyond the Basics' started by MyCameraEye, Mar 6, 2006.
  1. MyCameraEye
    MyCameraEye TPF Noob!
    Dec 11, 2005
    594
    12
    Washington D.C. Metro Area
    Normally I am posting answers in this forum bu today I need a solution.
    I have two fairly expensive filters jammed together. A 77mm Nikon UV and a B+W 77mm Polarizer. As you may know, the B+W is a very slim filter and has nearly nothing to grab onto to try to unscrew it from the Nikon filter and being it is a polarizer, the outside ring rotates freely so I am really stuck here. I have tried kitchen rubber gloves to get a good grip on them both and tried to turn with all my might but it would not budge.
    Scott
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    try needle-nose pliers?
  3. MyCameraEye
    Dec 11, 2005
    594
    12
    Errr I think this would be a last option. There must be a way to get them apart with out using tools that could slip and cause damage.
  4. df3photo
    df3photo TPF Noob!
    Dec 31, 2004
    629
    Erie Pennsylvania
    have you tried to spray it with a silicon spray? or some kind of lubricant? or tap it lightly (as not to break them) on the side on a table or something maybe that will jar em loose.
    maybe if you put a bit of cloth or something on the end of the needle nose (if you choose to go that way) it wont damage it as much.
    hmm... good luck. let us know how you figure it out.
  5. KMac
    KMac TPF Noob!
    Oct 24, 2005
    27
    Ontario
    I would try a rubber strap wrench. You also may want to try running the filters under hot water. The expansion may loosen things up a bit and the water would act as a temporary lubricant.
    Hope this helps,
    Kevin
  6. crawdaddio
    crawdaddio TPF Noob!
    Dec 5, 2005
    1,157
    14
    Central IL
  7. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    1. WD40. Then try.
    2. Put into freezer. Then try.
    Both are non-destructive.
  8. DestinDave
    DestinDave Master of Non Sequitur
    Jan 29, 2006
    480
    Not where I thought I'd end up
    Soak them in a warm/hot bath with a little bit of dish detergent. The soap will work into the threads and act as a lube but will also rinse off cleanly.
  9. Oldfireguy
    Oldfireguy TPF Noob!
    Jan 8, 2006
    987
    6
    Puyallup, WA
    They used to make a plastic filter wrench years ago. Don't know if they still do.
  10. Oscar Mueller
    Oscar Mueller TPF Noob!
    Aug 18, 2005
    88
    A little town in SE Wisconsin
    Put the two of them in the freezer over night. That should do it, if not, run some hot water on the filter with the female threads.
  11. MyCameraEye
    Dec 11, 2005
    594
    12
    I like this option the best. I will try this one first and let you know how it turns out.
    Scott
  12. MyCameraEye
    Dec 11, 2005
    594
    12
    I was about to put the filters in the freezer just when I got them apart. I said I tried some rubber (yellow) kitchen gloves but I also had some latex gloves I use for field dressing when I'm hunting so I decided to pull a pair out of the box and give it one last go. After a few trys, I managed to get the two filters seperated.
    Scott
camera filters stuck together
