Two things I have done lately that have improved my work/fun with the D5100
Discussion in 'Nikon Cameras' started by greybeard, Apr 28, 2012.
  1. greybeard
    greybeard Been spending a lot of time on here!
    Dec 30, 2011
    3,257
    703
    WV
    1. Assign the ISO function to the self-timer button.
    CUSTOM SETTINGS MENU->f Controls->f1 Assign Fn button ISO
    Coming from film, having control over ISO/ASA is a new thing to me. In the good/bad old days of film you set the ISO to what ever the film speed was and dealt with it for the entire roll. You could not change film speed in the middle of a roll. With these new fangled digital cameras ISO can be changed as easily as shutter and aperture. So why keep it buried in a menu, assign it to the self-timer button. Now, when you hold down the self-timer button and spin the control wheel, the ISO changes just like the other exposure controls. I think this really improves things.
    2. Use a White/Gray card for WB setting.
    SHOOTING MENU->White balance->PRE Preset manual->Measure->Overwrite existing preset data? (and then take a picture of your gray card)
    This procedure sets your D5100 to the existing light in the room. You have to do this every time your lighting changes but the white balance has been spot on for every thing I have shot using this method. I don’t use this for everything as it can be time consuming and I shoot RAW so I have control in PP.
    These procedures are described in detail in the manual.
    Just thought I’d pass this on.
    • Like Like x 5
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,473
    14,689
    USA
    Good suggestions, greybeard. The ability to use a "FUNC" button plus a camera control wheel to quickly enable or disable one's very own,personal, user-set custom FUNCtions is one of the Nikon innovations that have long earned the brand a reputation for superior ergonomics and control design ethos. Heck, even Canon has seen how well the Nikon FUNC button concept works, and has now introduced their very own version of the FUNC button! I agree with you on your amazement and joy about the ISO adjustability that these newfangled d-slr cameras have brought us! Need ISO 1,250 for ten frames? Need ISO 640 to give a little bit more flash bounce range? Want to bracket flash exposure results with an off-camera flash set to manual output control mode? ISO adjustment to the rescue!!!! It's pretty sweet--especially now that the very-newest sensors and cameras allow such good dynamic range and good color across more than just the base ISO values! Truly, we live in amazing times.
  3. otherprof
    otherprof TPF Supporters Supporting Member
    Nov 19, 2011
    1,539
    871
    Long Island, New York
    Thank you very much for the advice. I just assigned the ISO settings to the function button, and look forward to making use of this easy access to more control.
    • Like Like x 1
  4. Mrgiggls
    Mrgiggls TPF Noob!
    Mar 25, 2012
    193
    41
    Austin, TX
    Good call....if I didn't have a ISO button on my D90 I'd probably do the same. I have learned that auto-ISO is not a good thing a lot of the time. Coincidentaly, the Fn on my D90 is set in a closely related area of exposure...metering. I have my D90 set to matrix but when I need to spot meter I simply press the Fn button and there it is.
  5. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    15,671
    3,893
    Iowa
    Even back in the film days we did things to modify the ASA of the film. We occasionally set the ASA to a higher number, and "pushed" the developing process. Problem was, we had to process the entire roll to that specification. That is why some of us loaded some short rolls of only about ten shots when we knew before hand we were going to push the process. Of course, we often lost detail in the shadows, but the SPEED! When printing, we generally could burn in the detail areas a little to help.
    Using the function button for the ISO is a good plan.
  6. zamanakhan
    zamanakhan TPF Noob!
    Sep 2, 2010
    473
    29
    I wish I could do this with the d7000, I would love to control all the settings without having to take my hand off the lens.
  7. TamiAz
    TamiAz No longer a newbie, moving up!
    Sep 26, 2011
    992
    518
    Arizona
    Perfect timing.. I just bought a gray card last week and haven't had a chance to play with it. Now I know how!! :D Thanks for the tip on using the self-timer for adjusting iso.. I use my AE-L/AF-L for focusing and I find it much easier to use.
  8. Roman Smolkin
    Roman Smolkin TPF Noob!
    Oct 27, 2014
    Hi, just discovered that fn button for ISO, but how do you take a timer shot if the fn button is used for ISO?
  9. greybeard
    Dec 30, 2011
    3,257
    703
    WV
    I never use the self-time, I use a off camera radio trigger instead.
  10. DGMPhotography
    DGMPhotography Been spending a lot of time on here!
    Mar 23, 2012
    2,514
    542
    Richmond, VA
    You can just do it in the menu (press i), which works if you're not doing it all the time -just change from single or continuous to 10s.
  11. MichaelHenson
    MichaelHenson No longer a newbie, moving up!
    Nov 15, 2013
    746
    176
    St. Louis, MO
    Good stuff. I have a grey card, just haven't used it yet. Setting ISO to the FN button was one of the first things I did...
    Something else that I just discovered this weekend was the setting for focus lock. I though I'd had it set but kept running into issues whenever I would focus and recompose. Double checked all my settings again and found that, apparently, I'd set the lock button to AE lock? Fixed it and played with focus lock and some back button focusing...I think that from now on, with portraits, I'm going with back button focusing...I love having the ability to focus on a static object and recompose without accidentally taking a picture or losing focus (with the half shutter press + AF lock button) because my HUGE hands slip and accidentally finish pushing the shutter.
  12. sleist
    sleist Been spending a lot of time on here!
    Nov 8, 2009
    3,556
    1,810
    Boston
    Saved yourself some money.
    Upgrading gear won't get you as much as upgrading your brain.
    Nice post.
change function button for iso d5100
d5100 fn button
d5100 function key
fun things to do with nikon d5300
function button on nikon d5100
how to assign fn button on d5100
how to save custom settings on nikon d5100
nikon d5100 fn
nikon d5100 fn button
nikon d5100 function button
