U1 & U2 user settings?
Discussion in 'Nikon Cameras' started by markj, Apr 29, 2012.
  1. markj
    markj TPF Noob!
    Nov 25, 2011
    236
    16
    Lakewood Ranch, FL
    My D7000 has two user settings (U1 & U2) which are used for storing or saving a pre-configured set of instructions that can be called upon by simply rotating the mode dial. That part I understand, what is baffling is when would one use them? Excluding shooting into a photo light tent, where would one need to duplicate ones settings?
    If you are using these, could you please tell me what instructions have you saved and for what application it is to be used.
  2. digital flower
    digital flower No longer a newbie, moving up!
    Oct 18, 2005
    1,409
    36
    CT
    On my compact camera I use User1 as the monochrome setting and User2 with the macro focus engaged.
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,419
    8,012
    Iowa
    U1 has everything set to manual. Manual exposure, aperture, shutter speed, white balance, ISO.........
    U2 is basically the same as P, except for custom white balance.
    U2 is for 'snapshots'. U1 is for when I give a damn.
  4. markj
    markj TPF Noob!
    Nov 25, 2011
    236
    16
    Lakewood Ranch, FL
    Sparky, Why would you have to set all manual settings U1? I'm guessing you use manual 90% of the time, wouldn't your camera be set to manual anyways?
  5. 480sparky
    Mar 8, 2011
    22,419
    8,012
    Iowa
    "M" may not always mean manual WB or ISO. Programming it in U1 keeps me from having to set it that way.
  6. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Use them for where ever you might shoot a lot and the lighting doesn't change.
  7. Overread
    May 1, 2008
    23,838
    4,092
    UK - England
    I'm canon side, but we've similar features on some of our bodies as well. Personally I use them for a variety of different situations and how you use them will depend somewhat on the complexity of the camera and the custom options present - as well as your typical shooting subjects.
    For example I have mine setup to:
    Custom 1 - my macro mode - FPS is set to 4 instead of 8 (flash can't keep up with 8 in a burst) - mode is manual - ISO 200 - 1/200sec - f13 are the default starting settings.
    Custom 2 - wildlife grabshot - FPS 8 - ISO 400 - 1/400sec - and I'd have to check the aperture. Plus I've fiddled with some of the AF options to move them outside of their default values to get best performance
    In general just set them to suitable fast setting for when you want to shoot. If you find you don't change much/anything of the background settings or custom options then they will probably be of lesser use for you. If, however, you are often using lots of custom settings for key shoots then you can use the custom modes to at least let you start a shoot without having to re-set all the values and variables each time.
    Remember you can change the values in the custom mode at any point so you are not locked into shooting them unless you then save them as the new defaults.
d7000 u1 sample settings
how to use u1 and u2 in nikon d7000
using the u1 and u2 settings in nikon d7000
what nikon u1 settings can you set
