umbrellas and umbrellas
Discussion in 'Photography Beginners' Forum' started by VaE39, Jul 1, 2009.
  1. VaE39
    VaE39 TPF Noob!
    Jul 15, 2007
    92
    hey everyone,
    I've just recently started getting into portrait photography instead of urban/nature. I have 2 sb600's and I'm looking to get an umbrella. I'm thinking of something around 41"s. I want to start with one and see if I can utilize 1 before getting another. I'm not sure if I should get a white or silver surface or maybe a white surface that can also be a shoot-thru. Also, is a sb600 strong enough or do I need a stronger speedlight?
  2. DeadEye
    DeadEye TPF Supporters Supporting Member
    May 16, 2007
    960
    11
    Umbrellas are cheep, get em and play around. The silver will better utilize the low power of a speed light. The white will be softer and the shoot thru softer still.
    There are times that my studio pack on its lowest power is too strong and I have to use a nd filter to knock it back. Get the umbrellas and play.
    D.E.
  3. VaE39
    VaE39 TPF Noob!
    Jul 15, 2007
    92
    I found a good deal where I can get 2 umbrellas with a removable black background, 2 light stands, and 2 adapters for under $100. But they are only 32". Does 32 to 41" make a huge difference?
    Or should I stick with the higher quality 1 41" umbrella and use that first
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    The bigger the umbrella the softer the light will be...the bigger surface area means the light will be more diffused.
  5. KmH
    Apr 9, 2009
    40,538
    5,541
    Iowa
    The size of the umbrella is determined by what you are shooting.
    The smaller umbrella's are used for siongle head and shoulder shots.
    An umbrella in the 40" range can do a 3/4 shot.
    60' inchers are for full body and up to 2 people.
    It's best to learn how to use 1 light well and then 'graduate' to 2.
    A silver umbrella will give harsher light than white.
    If you don't already have it get the book "Light: Science and Magic. An Introduction to Photographic Lighting" by Fil Hunter, et al.
