N'Kolor
- Joined
- Oct 21, 2007
- Messages
- 342
- Reaction score
- 0
- Location
- Orlando, FL
- Can others edit my Photos
- Photos NOT OK to edit
Which do you perfer for portraits?
care to share how you made it?
It depends on what you are trying to achive. You have more control of the light with a softbox over an umbrella, but you can get a better spread of light over a larger area with an umbrella. Getting a wider spread of light can be very usefull when shooting a large group of people or going for full length or when you have an active kid or two moving around and you can't be changing your lights every minute or two.
A softbox can give you softer more diffused light, but sometimes you want light that is a bit stronger or harsher because of your subject. Umbrellas are also cheaper (in most cases). You can get a 60" umbrella a lot cheaper than a 60" softbox. On the other hand, a 60" umbrella takes up a lot more room than a softbox (realitively speaking when you consider the spread of the umbrella).
To throw something else into the mix, for soft light and something that is very cheap to make, a light panel is even better than a softbox. You can make a two panel 6' tall by 4' wide light panel out of PVC and white nylon (I like sport nylon over rip stop nylon) for one panel and black nylon for the other panel (to block the light towards the camera) that is free standing for about $30. With PVC you can make it different sizes as well and make it so it breaks down easy for storage and transport. That is a very large diffused light source. To get the same size light with a softbox would be very expensive.
I find that both umbrellas and softboxes (and light panels) have their place in the tool kit. They get along very well together.
Mike
